Graph and Graphic Table Report Examples
GRAPHS
Graph reports are a common way to display plots of dependent data vs. some independent datum. A gINT graph report allows you to combine drawing elements with the graph of values against a variety of scales.
Graphs require gINT Professional or gINT Professional Plus. They are not available with gINT Logs.
See [[Using gINT Downloaded Examples]] for instructions.
Description
Preview (PDF)
Units
Download (Zip)
Last Update
Multi-Graph Report Example
Triaxial Test plus Axial Strain
E/E
multi-graph dataset.zip
(v8i & later)
06 Jun 2012
Graph Report
Triangle plot (gravel + sand vs. silt vs. clay)
US Letter Size, English Units
E/E
grf_a_gnnl01.zip
(v. 6 & later)
view text file
09 Mar 2006
Graph Report
Hydrograph (water level vs. time)
E/E
grf_a_nnnl01.zip
(v. 6 & later)
view text file
09 Mar 2006
Graph Report
Compaction Test Plot
with rock correction
E/E
grf_a_gnnn01.zip
(v. 6 & later)
view text file
05 Mar 2006
Graph Report Stereonet Plot of rock fractures
A Size, US Setup
N/A
grf_a_rnnn01.zip
(v. 7 & later)
view text file
21 Feb 2006
A Size, Metric units
N/A
grf_a_rnnn02.zip
(v. 7 & later)
view text file
2 Mar 2006
A4 Size, Metric units
N/A
grf_4_rnnn01.zip
(v. 7 & later)
view text file
21 Feb 2006
GRAPHIC TABLES
Graphic Table reports combine a standard graph report of values with a tabular report of values.
Graphic Tables require gINT Professional or gINT Professional Plus. They are not available with gINT Logs.
Description
Preview (PDF)
Units1
Download (Zip)
Last Update
Well Installations
Development Graphical Table
Purge Graphical Table
Water Levels with Time Graph
E/E
gtb_a_ennl01.zip
(v. 5 & later)
view text file
16 Apr 2003
