gINT and HoleBASE Product Support
Following the gINT and HoleBASE product support announcement in January 2023 a Frequently Asked Questions document has been created to provide further details and outline migration options.
| | Product(s): | gINT Professional | |
| | Version(s): | N\A | |
| | Environment: | N\A | |
| | Area: | Data Entry | |
| | Subarea: | N\A | |
communities.bentley.com/.../271473
This tutorial is designed for beginning level gINT users, and is intended for self-study. It introduces the concepts and capabilities of gINT with illustrations and explanatory material, then walks you through the user interface and various modules.
You do not need any prior experience with gINT to use this tutorial, and it is a good first introduction to the program.
Table Of Contents:
- A Database Manager for Subsurface Exploration
- Separation of Data from Reports
- The Data Template – Key to Data Standardization
- Computation and Decision Logic in Reports
- Some gINT Report Samples
- Well Installations
- Fence Diagrams
- Tables
- Water Level Monitoring
- Slope Inclinometer Monitoring
- CPT Data
- Geophysical Data
- Report Design and Drawing Tools
- Grid Data Entry
- Graphical Data Entry
- Data Import and Export
- Exporting Reports to Graphic Files
- Symbols and Symbol Design
- Online Resources
- Downloads and Updates
- How-To Videos
- gINT Forum
- gINT White Papers
- gINT Tutorials and User Manuals
- gINT Online Help
- Understanding the gINT Work Environment
- The gINT Main Menu
- Projects, Data Templates and Libraries
- Project Database Files
- Data Template Files
- Library Files
- Changing Libraries
- System Properties Window
- The SETUP.GSH File
- The INPUT Application Group
- The OUTPUT Application Group
- The DATA DESIGN Application Group
- The REPORT DESIGN Application Group
- The SYMBOL DESIGN Application Group
- The DRAWINGS Application Group
- The UTILITIES Application Group
communities.bentley.com/.../24994.performing-data-entry-tutorial
| | Original Author: | Kathleen Holcomb |
