| | Product(s): | gINT Professional | |
| | Version(s): | N\A | |
| | Environment: | N\A | |
| | Area: | Data Entry | |
| | Subarea: | N\A | |
communities.bentley.com/.../271336
This tutorial is designed for beginning and intermediate level gINT users, and is intended for self-study. It covers the essentials of gINT data entry, including grid input of data into standard tables, previewing and printing report output, customizing the data entry environment, tips and tricks, minor database modifications, and basic import and export. It employs some explanations, but mostly has you perform step-by-step instructions in gINT.
Table of Contents:
- Using this Tutorial
- Projects, Data Templates and Libraries
- Project Database Files
- Data Template Files
- Library Files
- What we will Create
- Monitoring Well Log
- Stratigraphy and Groundwater Fence
- Changing Libraries
- Creating a New Project Database
- Grid Input of Field Data
- Project Tab
- Company Information Dialog Box
- Borehole Tab (POINT Table)
- Relational Database Structure of gINT Data
- Lithology Tab
- Adding Lithology Comments
- Sources of Selection List Values
- Sample Tab
- Water Levels Tab
- Well Tab
- The OUTPUT Tab
- Report Preview
- Zooming
- Panning
- Viewing a Report with Data from a Multiple-Borehole Project
- Report Printing
- Previewing in INPUT
- Automatically and Manually Saving Data
- Formatting Table Grids in INPUT
- Changing Column Order
- Changing Column Widths and Row Heights
- Changing the Number of Header Text Lines
- Vertical Column Headings
- Showing and Hiding Fields
- Updating the Data Template
- Modifying Field Properties
- Captioning a Field (or Table)
- Required and Do Not Display
- Field Rules
- Default Field Values
- Using Lookup Lists and Library Tables
- Using a Lookup List
- Creating and Using a Library Table
- Importing and Exporting Data
- Exporting to a Spreadsheet
- Importing from a Spreadsheet
- Creating a Blank Spreadsheet
- Importing Data Directly from Project to Project
- Viewing a Fence Report
- The UTILITIES Tab
- Extract from Zip
- Library Merge/Copy
- Print Object Lists
- Repair/Compact Databases
- Appendix A -- Graphical Data Input
- Appendix B -- Tree View
- Appendix C -- Grid Input Tricks and Tips
- Renaming Boreholes
- Using Copy and Paste
- Replicating a Point
- Using View Entire Table to Locate Information
- Text Macros
- Keyboard Shortcuts
- Spelling Check
communities.bentley.com/.../25642.getting-to-know-gint-tutorial
| | Original Author: | Kathleen Holcomb | |
