| Product(s): | gINT Professional, gINT Professional Plus | ||
| Version(s): | N/A | ||
| Area: | Report-Graphic Text Doc | ||
| Subarea: | |||
| Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
A variable legend entity creates a legend displaying the material, sampler, well or other symbols in use in a single log, all boreholes on a fence report, or throughout a project (displayed in a graphic text doc). This is a useful visual aid on a report. The legend is called variable because the set of symbol boxes that appears will vary from log to log or fence to fence, depending on which symbols are in use.
To show the symbols in use in a project we will create two Graphic Text Doc reports, one in landscape and one in portrait orientation. Each will include two legends, one for material and one for sampler graphics. Then we will demonstrate how to specify the order of symbols.
Note: This exercise requires the use of training.GPJ project and training.GLB library available from: download.aspx. Instructions for unzipping and setting up these files is on: using gint downloaded examples.aspx.
Go to File->Change Library. Select training.glb and click Open.
In REPORT DESIGN, select the Graphic Text Docs tab.
Click the New icon or select File->New. The ‘New...’ dialog box appears.
In the General tab, click Reset, then enter the following:
| Field | Value | Comments |
| Name | SIMPLE LEGEND | Name that appears in the report object selector |
| Description | Legend of material and sampler graphics used | |
| Left Margin | 0.6 | |
| Bottom Margin | 0.425 | |
| Page Size | Letter | |
| Orientation | Portrait | |
| Template | data entry.gdt | |
| Key Set | Project | Specifies the level at which data is consolidated |
Click OK. The empty report is created.
We will use the TITLE PORTRAIT block from the Drawing Library to create borderlines and header text. Select Blocks->Insert Block. In the BLOCK PROPERTIES dialog box, click Reset then enter the following:
| Block Source | Dwglib!title portrait | Click the Browse icon, select a Type of ‘DWGLIB’ and a Block of ‘TITLE PORTRAIT’. |
| Design Mode Color | Very Light Red | Color in REPORT DESIGN for the block insert and contents. |
| X | -2 | X coordinate of alignment point for block insert. No effect on output. |
| Y | 8.5 | See X. |
Click OK.
The report needs a title. Select Draw->Text->Text or click the Text icon, click Reset, then enter the following:
| Text Expression | PROJECT SYMBOL LEGEND | |
| Height | 0.14 |
Character size of description text. |
| Horizontal Alignment | Right | |
| Vertical Alignment | Top | |
| X | 7.5 | |
| Y | 10.1 |
Click OK.
We need a centered title above the first legend, which is for Material graphics. Select Draw->Text->Text or click the Text icon, click Reset, then enter the following:
| Field | Value |
| Text Expression | Material Graphics |
| Height | 0.14 |
| Horizontal Alignment | Center |
| X | 3.8 |
| Y | 8.85 |
Click OK.
Next we create a variable legend for material graphics. Select Graphic Text->Variable Legend, click Reset, then enter the following:
| Field with Data | <<LITHOLOGY.Graphic>> | Source field for symbols. Use the Data Tool. |
| Symbol Type | Material Graphics | Type of symbol to display. |
| Number of Rows | 4 | Four rows of symbols. |
| Row Spacing | 0.6 | Row height. Needs to exceed rectangle height by some small distance for spacing. |
| Number of Columns | 6 | Six columns of symbols. |
| Column Spacing | 1.25 | Width of each column. |
| Fill Order | By Row | Symbols populate the legend from left to right. |
| Rectangle Height | 0.4 | Symbol rectangle height. |
| Rectangle Width | 0.4 | Symbol rectangle width. |
| Gap Between Descriptions and Rectangles | 0.04 | |
| Text Height | 0.08 | |
| X | 0.06 | |
| Y | 8.6 |
Go to the Symbol Descriptions tab and specify the following:
| Name and/or Description | Name: Description | Specifies whether the Name (symbol code), Description or both appear, and if both, in what format. We’re printing the code first, then a colon, then the description. |
Click OK.
To add a centered title above the sampler graphics legend, select Draw->Text->Text or click the Text icon, click Reset, then enter the following:
| Field | Value |
| Text Expression | Sampler Graphics |
| Height | 0.14 |
| X | 3.8 |
| Y | 6.0 |
Click OK.
To create a variable legend for sampler graphics, select Graphic Text->Variable Legend, click Reset, then enter the following in the Main tab:
| Field | Value |
| Field with Data | <<SAMPLE.Graphic>> |
| Symbol Type | Sampler Graphics |
| Number of Rows | 2 |
| Row Spacing | 0.6 |
| X | 0.06 |
| Y | 5.75 |
| Field | Value |
Click OK.
Go to OUTPUT->Graphic Text Docs and preview the result.
Close the preview.
A useful variant is the vertical project symbol report. To create this, do the following:
Go to REPORT DESIGN->Graphic Text Docs.
Select File->Copy Page. Name the copy ‘SIMPLE VERTICAL LEGEND’.
Double-click the ‘Material Graphics’ text entity, change the following values, then click OK:
| Field | Value |
| Horizontal Alignment | Left |
| X | 0.06 |
Double-click the ‘Sampler Graphics’ text entity, change the following values, then click OK:
| Field | Value |
| X | 3.8 |
| Y | 8.85 |
Double-click the material graphics variable legend entity, change the following values, then click OK:
| Field | Value |
| Number of Rows | 14 |
| Number of Columns | 2 |
| Column Spacing | 1.5 |
| Fill Order | By Column |
| X | 3.8 |
| Y | 8.6 |
Go to Output->Graphic Text Docs and preview the report.
Close the preview.
The Variable Legend entity in logs, fences, and graphic text documents, by default, prints the symbols in the order that they were encountered in the output. You can override this default behavior for sampler, material, well and/or general symbols using the Symbol Legend Positions feature in SYMBOL DESIGN, which enables you to assign rankings to symbols for display in legends.
For example, you might want to order material symbols to show gravel symbols first, followed by sand, silt, clay, rock, and all others. To do this you would assign an integer to all gravels you use, a higher integer for all sands, and so on. You can skip values. It is only the relative values that are important, that is, 5 will sort before 8 and it doesn't matter that there are no 6 or 7 values. Also, you can have multiple symbols with the same legend position values, and symbols with unspecified values are placed at the end of the list.
We’ll assign the following values to material symbols used in our project:
| Code | Description | Legend Position |
| CL | USCS Low Plasticity Clay | 4 |
| CLS | USCS Low Plasticity Sandy Clay | 4 |
| GW-GC | USCS Well-graded Gravel with Clay | 1 |
| ML | USCS Silt | 3 |
| SANDSTONE | Sandstone | 5 |
| SC | USCS Claey Sand | 2 |
| SILTSTONE | Siltstone | 5 |
| SM | USCS Silty Sand | 2 |
| SP | USCS Poorly-graded Sand | 2 |
To demonstrate the feature, do the following:
Go to SYMBOL DESIGN and select the Material tab.
Select File->Symbol Legend Positions. The Symbol Legend Positions dialog box appears.
Enter the legend position values in the corresponding rows from the list above, then click OK.
Go to OUTPUT->Graphic Text Docs. Preview the output. The material symbols are now in gravel-sand-silt-clay-rock-other order.
Close the preview.
Variable Graphic Log Report Legend: 12406.variable graphic log report legend.aspx
Variable Graphic Legend Showing All Material Graphics Used on a Fence:
12407.variable graphic legend showing all material graphics used on a fence.aspx
