Project Database - gINT
Add or Delete a Field in the Project or Data Template - Short Videos
Build a Data Template from Report Forms
Change a Field or Tab Name
Compare Projects or Data Templates, or Libraries
Create a Lookup List and Link it to an Input Field - A Short Video
Create a New Project - A Short Video
How to Convert DOS Version 3 gINT Projects
Importing/Merging Tables and Fields from Projects, Data Templates, Excel and Other File Types
Showing/Hiding Table Tabs and Fields, Reordering and Organizing Table Tabs
Sorting Boreholes Intuitively or With a Custom Sort Order
What is a Data Template?
