| | Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | |
| | Version(s): | N\A | |
| | Environment: | N\A | |
| | Area: | Report-Fence | |
| | Subarea: | N\A | |
communities.bentley.com/.../271468
Using This Tutorial
Download tutorial here.
This tutorial is designed for intermediate level gINT users, and is intended for self-study. It covers the options for modeling geotechnical data, including designing and customizing a fence report, importing and exporting data between gINT and surfacing/modeling software, and drawing cross-sections on a fence report.
You should be familiar with gINT data entry and basic output (including preview and printing, and the zoom tools) before working through this tutorial. We recommend you work through the Performing Data Entry tutorial if you do not have that familiarity.
Contents
- Using this Tutorial
- Building a Fence Report
- Understanding Fences
- Specifying Report Properties
- The General Tab
- The Data Frame Tab
- The Divisions Tab
- The Scales Tab
- Adding a Graphic Column Entity
- Previewing the Report Output
- Adding Grid Lines
- Adding a Borehole Number to Each Fencepost
- Offsetting the Fenceposts from the Axes
- Inserting a Frame and Title Block
- Creating Water Depth Symbols
- Adding Two Report Headings (one of them user input)
- Adding Axis Labels
- Setting the Print Order and Background Fill
- Converting a Fence Report from Letter Size to x
- Creating Multiple Column Fenceposts
- Adding Text vs Depth Columns
- Modeling Overview
- Contouring Data Using Surfer and gINT
- Generating and Plotting Data in Surfer
- Plotting Surfaces on D Fences
- gINT and Rockworks®
- Drawing Cross-Sections on Fence Reports
- Designing a New Symbol for the Top Layer
communities.bentley.com/.../24891.advanced-log-report-design-tutorial
| | Original Author: | Kathleen Holcomb | |
