| | Applies To | | |
| | Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | |
| | Version(s): | 8.x | |
| | Environment: | N\A | |
| | Area: | Symbol Design | |
| | Subarea: | N\A | |
| | Original Author: | Kathleen Holcomb, Bentley Technical Support Group | |
Note: This exercise requires the use of training.gpj project and training.glb library available from: download.aspx. Instructions for unzipping and setting up these files is on: using gint downloaded examples.aspx.
Symbol Design Tutorial Part 2: What Fills Do inside a Shape
Let’s experiment with applying some fills and notice how they behave. Do the following:
Important: Ensure that training.glb is the current library and training.gpj is the current project.- Go to DRAWINGS
General Drawings. - Select the Rectangle
tool, and create a rectangle with a first point of ‘0,0’ and a second point of ‘3, 1’ (using the coordinates box at lower left). - Select the Rectangle tool again, and create a rectangle with a first point of ‘4,0’ and a second point of ‘7,3’.
- Select the Zoom Window
tool and draw a zoom rectangle that just surrounds the two rectangles in the drawing. This displays them in a closer view.
- Double-click on one of the edges of the rectangle at left. The POLYLINE PROPERTIES window opens.
- Click the Browse
button to the right of Fill Type[!Symbol] text box. Select a Type of ‘Solid’ and click OK. - Click the Configuration tab. In the Override Fill Color drop-down list, select ‘Very Light Red’. Click OK.
- The rectangle appears in solid black. To see its actual color, click the Preview
icon, then close the preview. - Double-click the left rectangle. Click the Browse button on the Fill Type[!Symbol] text box, select a Type of ‘TILE’, and a Symbol of ‘LINE30D01’ (to go to this symbol in the Symbol dropdown list, press the ‘L’ key when the list is showing).
- Click OK to close the Fill Symbol dialog box, and again to close the POLYLINE PROPERTIESdialog box. The rectangle is filled with a pattern of diagonal lines. Click Preview to see that the lines are red, and then close the preview.
- Double-click the left rectangle, click the Browse button on the Fill Type[!Symbol] text box, select a Type of ‘MATL’ and a Symbol of ‘GP-GC’. Click OK to save the fill symbol, and again to close the POLYLINE PROPERTIES.
- Double-click an edge of the right rectangle, and specify the same fill symbol (Type of ‘MATL’ and a Symbol of ‘GP-GC’), then close the POLYLINE PROPERTIES. (We’ll ignore color from this point on, and not preview). Notice how the symbol is applied similarly in the two rectangles.
- Because of how this symbol is defined, the left 50% of any shape to which it is applied will have the light pattern, and the right 50% will have the dark pattern.
- Double-click the left rectangle, and specify a Type of ‘SAMP’ and a Symbol of ‘GB’, then close the POLYLINE PROPERTIES. Do the same in the right rectangle.
Notice that this symbol retains its original proportions as it is made larger.
- Double-click the left rectangle, and specify a Type of ‘SAMP’ and a Symbol of ‘AU’, then close the POLYLINE PROPERTIES. Do the same in the right rectangle.
- Notice that the auger symbol is repeated as you increase the height of the area being filled, but its components always occupy the same proportions from left to right.
- Click the Save icon, and specify a filename of 'symbols test'. We will re-use this drawing for additional experiments in Part 3 of this tutorial.
We will see how these kinds of different symbol behaviors, as well as other behaviors, are configured in a material or sampler symbol, and the tiles from which it is composed in Part 3 of this tutorial.
