gINT Standard Reports
Available gINT Standard Reports
Each set of files contains a library with report templates, a sample project and a data template.  The report templates in these libraries have been designed to support the production of your reports. While we have worked to ensure these templates produce correct results, we make no warranty of suitability or correctness. These files are provided at no charge and they are to be taken as-is. You are free to modify these files.  These files are also available in the gINT installer.
Click the Country/Standard link to download the gINT files.  Instructions for unzipping and setting up these files are on Using gINT Downloaded Examples.aspx.
Click the PDF links to view examples of these files.
Country/Standard
PDF
Paper
Size
Units
Soil Classification
A4PDFA4/A3Metric--
A4  with Lab/ASTM PDFA4/A3MetricASTM
A4 with Lab/BSI
PDFA4/A3MetricBSI
AGS 3.1
PDFA4/A3MetricBSI
AGS 4.0PDFA4/A3MetricBSI
AGS 4.0.4PDFA4/A3MetricBSI
Australia PDFA4/A3Metric--
CanadaPDFLetter/ LedgerMetric--
Canada with Lab
PDFLetter/ LedgerMetricASTM
Czech Republic
PDFA4/A3Metric--
India
PDFA4/A3Metric--
South Africa
PDFA4/A3Metric--
Spain PDFA4/A3Metric--
Spain with Lab PDFA4/A3MetricASTM
US PDFLetter/ LedgerImperial--
US with Lab PDFLetter/ LedgerImperialASTM
