The following download types are available on request. Click on the header to go to the relevant page for that item.
Component files (HBC's) cover a wide range of updates that effect HoleBASE, usually within a configuration pack but sometimes at system level too. These can cover everything from model updates, to borehole templates and many more.
A configuration pack is the part of the application that holds all of the components within. For example, a configuration pack may contain many of the following; Sections, Site Plans, Model Changes, Import / Export mappings or Log Templates. These are generally set up for use per region on this website.
Coordinate Systems are the mapping component that allows HoleBASE SI to work with any coordinate system around the world.
