The following download types are available on request. Click on the header to go to the relevant page for that item.
The default templates are the sheets that can be opened within Excel, then have data entered within them that relates to the type of template and then the data can be exported into AGS format with the use of KeyAGS.
The tutorial files are a set of excel sheets that have been designed to introduce you to the basics of KeyAGS and its powerful features. Although these templates are mainly aimed at being used in a learning capacity, they may also be useful in some production environments.
