To ensure a smooth transition of work and effectiveness of your daily workflows with gINT Civil Tools we have assembled this wiki to help ensure a smooth transition of work from home with gINT applications.
When working remotely, the best practice is to send a company issued laptop or access remotely.
If you are accessing files from a laptop at home and your accessing gINT files (project, library) that are located on a company server you would need VPN access.
The user may experience slowness or a perceived lag in performance. The perceptions may be caused due to a variety of non-gINT Civil Tools hurdles such as Wi-Fi bandwidth, VPN bandwidth, etc. An alternative would be to copy your gINT files locally (project, library).
Installation Requirements
A CD drive or access to the Internet is required for product installation. The minimum sys tem configuration for installation is:
| Supported Operating Systems |
Note: Windows 7 operating system is supported only if you have its service pack (SP1) installed.
Note: You must have the following Microsoft updates installed on your machine:
Bentley does not support its software running on Microsoft operating systems versions that Microsoft has "retired". For more information on Microsoft's application retirement policy, click here. For similar information on Bentley products, refer to the Bentley Product Support article. |
| Communications Protocols |
| Software Prerequisites | The Prerequisites for Bentley Desktop Applications are automatically downloaded and installed to your workstation while you install gINT Civil Tools Professional Plus. The contents of the Prerequisites for Bentley Desktop Applications include:
Microsoft Internet Explorer, minimum v11.0, with 128-bit cipher strength. Microsoft no longer supports any versions prior to v11.0. Internet Explorer is not installed as part of the product pre-requisites. Copyrights in all components are owned by Microsoft Corporation or one of its affiliates, subsidiaries, or licensors. |
Minimum Profile
The minimum recommended workstation profile for running gINT Civil Tools CONNECT Edition is:
| Processor | Intel® or AMD® processor 1.0 GHz or greater. gINT Civil Tools is not supported on a CPU that does not support SSE2. |
| Memory | 4 GB minimum, 16 GB recommended. More memory almost always improves performance, particularly when working with larger models. |
| Hard Disk | 20 GB free disk space (which includes the 12 GB install footprint for a complete installation) |
| Video | See the graphics card manufacturer for latest information on DirectX drivers. 512 MB of video RAM or higher is recommended. If insufficient video RAM or no graphics card supported by DirectX can be found, gINT Civil Tools Professional Plus attempts to use software emulation. For optimal performance, graphics display color depth should be set to 24-bit or higher. When using a color depth setting of 16-bit, some inconsistencies will be noted. For more information on recommended workstation profiles for gINT Civil Tools Professional Plus, see MicroStation System Requirements and Hardware Recommendations. |
| Screen Resolution | 1024 x 768 or higher. |
All Bentley software is downloaded from the Bentley Software Downloads pages: https://softwaredownloads.bentley.com/
General download and installation directions are available here.
gINT Civil Tools has two license levels: gINT Civil Tools Professional and gINT Civil Tools Professional Plus. Unlike gINT, the tier you download from Bentley's Fulfillment center is the tier you install. You want to be sure to download and install the level of gINT Civil Tools that matches the license level of gINT for your organization and/or on your PC to avoid term licenses or overage charges .
If you are a current gINT user, Civil Tools Professional and Professional Plus are included with your gINT Professional or Professional Plus license and Annual SELECT or ELS subscription. You can download, install, and use it at any time.
You do not need to have gINT installed to install gINT Civil Tools. However, it will still register as a license usage of gINT.
For an overview of some of the exciting capabilities of gINT Civil Tools, please visit the videos section of this Communities page as well as our YouTube page.
Sharing Configurations And Project Data
When you’re working remotely, you are still part of a team and therefore sharing of project data is crucial. This is where the Configuration system shines. No matter where you are, you can be sure to be using the correct CAD standard with server-based Configurations. If your system has already been configured to use server-based resources virtualization and remote desktop access results in a similar experience to working in the office, there may be some graphic latency, but the system will be identical.
Attempting to connect to a configuration on office-based shares via VPN may be possible, depending on your IT systems, but is likely to be subject to significant latency, especially with many more VPN users than usual. Working with a local copy of the network configuration may be more appropriate. Applications can be configured to automatically switch to a local configuration for home working. The linked solution is primarily aimed at short term scenarios. If longer term home working becomes a necessity, a remote access or document management solution may be the appropriate option to avoid problems with version control and duplication of documents.
If your system is not currently configured to share standards and data planning for home working may be an opportunity. CONNECT Edition is easier to reconfigure to the network than previous versions. In outline, one of the simplest and effective ways of work sharing is by storing your standards and project data in a common network locations and pointing every user’s configuration to those locations. Some guidance on achieving this can be found in:
CONNECT Edition - Custom Configuration Guides
Your organization can have one or more Administrators who can assist with Bentley license management, downloads, assigning permission, etc. A list of your Administrators can be seen by going to https://connect.bentley.com. Below the Welcome Banner, click on the 'How are you CONNECTED?' link; you will find a list of your site Administrators in the “Administrators” tab (with email addresses)
Please check this video presentation that explains the effective workflow for using gINT Civil Tools at home or remotely.
