Product(s): | Keynetix | ||
Version(s): | 1.0 | ||
Area: | Assist |
Date: November 7th 2018
This webinar will introduce the Connector that links the Chemtest’s Chemsolutions with Keynetix's HoleBASE SI.
The connector will save time and minimise errors when scheduling environmental testing for site investigations, as it allows sample information and test scheduling data entered into a HoleBASE SI project to be sent directly to Chemtest via the connector.
The webinar will cover how the system works and how the user can:_
This is a joint webinar between Chemtest and Keynetix.
