| Product(s): | Keynetix | |
| Version(s): | 1.0 | |
| Area: | Assist | |
Webinar US50 - The Big One
Date:1st March 2019
Presenters: Gary Morin, Oliver Carnaby, Phil Child, Roger Chandler and Steve Evason
In the next of our Small Steps Series Webinars, we are celebrating a big milestone with our 50th Small Step Webinar. In this special hour-long event, the whole Keynetix Webinar team will be brought together to show their top 50 tips across the entire Keynetix product range with a little bit of something shown from everything ranging from Template Design, Data Entry, Lab Testing, Civils Modelling and much more.
Gary Morin, Oliver Carnaby, Phil Child, Roger Chandler and Steve Evason will all come together to show 10 tips each with the following rules;
Each presenter must show 10 tips
At least 2 different pieces of software must be shown by each presenter
Each tip demonstration is a maximum of 1 minute
We will also be doing the traditional ‘Questions at the end’ so that you can ask the whole webinar team any of the tricky questions that you have been saving up for the whole team to come together and answer.
Tip List
- Tip 1 - Merge Across
- Tip 2 - Option Buttons
- Tip 3 - Option Buttons Plus
- Tip 4 - Search and Filters in KeyLAB
- Tip 5 - Keep KeyLAB Clean and Fast
- Tip 6 - Test Ordering in KeyLAB
- Tip 7 - Test Naming in KeyLAB
- Tip 8 - Laboratory Status Reports
- Tip 9 - AGS Data to Laboratories
- Tip 10 - Test Names from KeyLAB
- Tip 11 - Freeze Panes
- Tip 12 - Search It
- Tip 13 - Browse It
- Tip 14 - Need an Expression? Cheat!
- Tip 15 - Copy and Pasting
- Tip 16 - Personalising the Interface
- Tip 17 - Keyboard Shortcuts
- Tip 18 - Creating Key Sheets
- Tip 19 - Count It
- Tip 20 - Filter It
- Tip 21 - Be Specific
- Tip 22 - Focus the Map
- Tip 23 - Do Your Research
- Tip 24 - Review Import Changes
- Tip 25 - Don't Overlook (Validation) Report Views
- Tip 26 - Marry a Log Template and a Data Entry Profile
- Tip 27 - Snapshot for Safety (Get Out of Jail Free)
- Tip 28 - Focus the Project Exporter
- Tip 29 - Subdivide your Site
- Tip 30 - Associate Colour with Geology Codes
- Tip 31 - Section the Whole Site
- Tip 32 - Merging Geologies on Strips
- Tip 33 - Locate Boreholes Before Drilling
- Tip 34 - Default Values
- Tip 35 - Single Borehole Mode
- Tip 36 - Pivot Table Summary
- Tip 37 - Cloud Mapping
- Tip 38 - Web Data Checker
- Tip 39 - Change the Borehole Plan Symbols
- Tip 40 - Save Civils Styles to Template DWG
- Tip 41 - Lock Plan Strips
- Tip 42 - Profile Strip Text Sizes
- Tip 43 - Fit Hatch Scales to Log Strips
- Tip 44 - Declutter your Profile Strip Headers
- Tip 45 - Add a Ground Surface to Profile Views
- Tip 46 - Adding Groundwater as a Profile
- Tip 47 - Projecting Foundations on Profile Views
- Tip 48 - Use Interpretations to Correct Profiles
- Tip 49 - Extending your Site Beyond the Boreholes
- Tip 50 - Dynamic Differential TIN Surfaces - Its Magic!
https://vimeo.com/320832524
Want more free webinar recordings?
Please note that a login is required for access to the webinar archive. Registering is quick and easy, just click on the register button on the top right hand side of the screen.
