| Product(s): | Keynetix | ||
| Version(s): | 1.0 | ||
| Area: | Assist |
Should I install HoleBASE SI Standard or Professional?
When installing HoleBASE SI, you are presented with options to install either the Professional or Standard versions of HoleBASE SI. The version that you should install will be dependant on the version that you have licences for. If you do not have a licence for one of the products, you will not be able to run it.
In organisations with more than one licence, it may be applicable that there are multiple licences available, some Standard, some Professional. In this case, it may be worth reviewing whether to install one, or both of the versions.
If you wish to use all of the powerful features of the HoleBASE SI product, including;
Then HoleBASE SI Standard is the recommended version that you should install.
If you wish to use all of the powerful features of HoleBASE Standard, plus;
Then HoleBASE SI Professional is the recomended version that you should install.
It is perfectly acceptable to have both versions installed on the same machine. In this setup, a licence of Standard could be used for day to day tasks, leaving the Professional licence free for other users to use.
