| Product(s): | Keynetix | |
| Version(s): | 1.0 | |
| Area: | Assist | |
How To create a Location Group in HBSI
Explanation
Location groups can be used in HBSI, Excel Extension, Civils Extension to run reports or just select a group of locations rather than all locations.
Process
Below you can find some instructions on how to create a Location Group in HoleBASE SI;
- Open HBSI and your project
- Select the "Data Tab
- Select "Location Groups"
- Use the "Create" option to make the location group
- Give the location group a name and "save"
- Now select the "locations" option
- Highlight the locations you want to include in the group and then use the "Add Selected" option to add the locations to the group.
- Close the window.
