| Product(s): | Keynetix | ||
| Version(s): | 1.0 | ||
| Area: | Assist |
In this video Gary Morin walks through the entire process involved in identifying geology lenses from borehole data and applying AutoCAD Civil 3D functionality along with HoleBASE SI to create a 3D model including several material lenses.
The techniques in this video can be used for geology modelling or contamination modelling as the HoleBASE SI Extension for AutoCAD Civil 3D allows you to access all the data in your HoleBASE SI project not just the geology data.
