Product(s): | Keynetix | ||
Version(s): | 1.0 | ||
Area: | Assist |
When installing the "HoleBASE SI Excel Extension"or "KeyAGS", you may receive the following message;
"A compatible version of Microsoft Visual Studio Tools for Office is not installed. Please run setup.exe"
This can be resolved by, opening the "Installer zip file", open the "VSTOR40" folder.
Finally, run the "HoleBASE SI Excel Ext installer" or the "KeyAGS installer" again and proceed as normal.
