How to use Filter Groups in Template Studio
 Product(s):Keynetix
 Version(s):1.0
 Area:Assist
Explanation
Filter groups are used in Template Studio to filter out results of a specific value. For example you may have many sample types but for some reason only need to show "B" (Bulk). To make Template Studio filter on "B" you first need to set up the filter group.
Process
Please follow the steps below;
Select your condition
Select your value
Select "ok" to save the changes and then "ok" again to the following window.
Now when you preview the template it should filter the results based on your filter group.
