How to find out which version of Office you have installed so you know which installer to use for Ke
 Product(s):Keynetix
 Version(s):1.0
 Area:Assist
How to find out which version of Office you have installed so you know which installer to use for KeyLAB
Issue Summary
Microsoft Office has different bit version's, see below on how to find out what version is installed on your PC/Laptop, so you know which installer use
Resolution
Open Microsoft Excel, then go to File
Then go to Account
Then go to About
Once you have clicked on About Excel, you will see what bit version of Microsoft Office you have installed. You can now download and install the correct installer of KeyLAB that matches the bit version of Office installed
