| Product(s): | Keynetix | ||
| Version(s): | 1.0 | ||
| Area: | Assist |
When checking an AGS file through the AGS Checker and you get an error message saying "Error Processing file, unable to store file"
First check that there are no illegal characters in the file name ie any apostrophe's ('), if there are rename the file without the illegal characters
Try moving the file to your desk top, this is especially important if the file name is long
Open the AGS file and check the version, if this is listed at 4 change this to 4.0. Also if this is listed as 4.0.3, again change this to 4.0
(The last option is fixed in the latest release, we recommend downloading this from this website as soon as possible to ensure that no further issues are found.)
