| Product(s): | Keynetix | ||
| Version(s): | 1.0 | ||
| Area: | Assist |
The following videos will take you through the process of getting up and running with the HoleBASE SI Civils Extension and all of the main processes that are involved with this.
Getting Started Videos for our other software can be found on the right hand side of this page.
Click on a video to see more.
The following video shows how to get started within AutoCAD Civils Extension and how to Connect to a HoleBASE SI Database.
The following video shows how to get started working with layers in the Civils Extension and how the extension uses layers to plot information.
The following video shows how the location manager works and how to quickly plot borehole locations, strips and geology sticks.
The following video shows how the strata manager works and how to create geology surfaces.
The following video shows how the hatch manager works and how to create and edit hatch sets so that the outputs you create match your needs.
The following video shows how to create profile views that show a section from the geotechnical model in a 2D space and how to customise these to match what is needed.
The following video shows how the style manager is used to control how all of the objects are presented within your drawings and how to quickly adjust this to show them in the way that is needed.
The following video shows how to use the legend key funtionality to plot a key item within the drawing showing the hatches used within strips, sticks and the 3D model
The following video shows how to use the interpretation functionality to create profiles quickly, edit them and push the interpretations back onto the surfaces themselves.
/cfs-file/__key/communityserver-wikis-components-files/00-00-00-01-05/0042.MissingImage.png to the how to video for modelling complex geology mentioned in the article.
The following video shows how to create 3D fence diagrams and use these to show 3D representations of the profiles and alignments in your drawing.
The following video shows how to plot data from your HoleBASE database into points within your drawing.
The following video shows how to plot data from your HoleBASE database into surfaces within your drawing.
