The below specifications are for the minimum and recommended hardware specifications recommended by Keynetix. These should be seen as only a guide for using the software and we would advise for you to contact our support team for more information regarding your specific set up.
Specifications for all Desktop Software (HoleBASE, KeyLAB etc)
Minimum
- Dual Core Intel or compatible 2GHz processor
- 4GB of RAM
- 5GB of available hard drive space
- 1600x900 resolution
- Windows 7 with Service Pack 1
- Internet Connection
Recommended
- Quad Core Intel or compatible 2GHz processor
- 8GB of RAM
- 10GB of available hard drive space
- 1920x1080 resolution
- Windows 10
Specifications for Servers (SQL Server and Licencing)
Minimum
- Intel Dual Core Xeon CPU
- 4GB of RAM
- 50GB of available Storage
- Windows Server 2008 r2
- 50Mb Network Connection
Recommended
- 2.4Ghz Quad Core Intel Xeon CPU
- 8GB of RAM
- 50GB of available Solid State Storage
- Windows Server 2012 r2
- 1 Gb Network Connection
Legacy note for HASP users : It is only possible to run one instance of the Network Licence Manager on a single machine. If further licences are required then they must either be added to the current Licence Manager and therefore Maintenance Agreement, or, they must be run from a different licence manager and server.
