A data entry template allows for quick and easy entering of information into your HoleBASE SI database. Each template is specifically designed to allow for a certain type of data to be inserted. For example, a Trial Pit template is set up to allow for any data that may be associated to a trial pit to be entered. Once imported, these templates will then be available within the Data Entry Module, both inside of HoleBASE and within the standalone tool.
The following downloads are compatible with the Data Entry Module and HoleBASE SI.
To download any of these files, please put in a service request with our support team at https://apps.bentley.com/srmanager/ProductSupport with the filename in the description and a member of our support team will send a copy of the file to you.
These can be loaded into HoleBASE SI Professional or HoleBASE SI Standard build 1.18.0.x or later by following the steps below:
The following downloads are sectioned up into the relevant regions.
| Item | Version | Description | Filename | Date Added |
| Cable Percussion | 1.0 | Download for the Data Entry Profile for Cable Percussion locations | CablePercussion.hbc | 04th April 2016 |
| Dynamic Probe | 1.0 | Download for the Data Entry Profile for Dynamic Probe locations | DynamicProbe.hbc | 04th April 2016 |
| Rotary Core | 1.0 | Download for the Data Entry Profile for Rotary Core locations | RotaryCore.hbc | 04th April 2016 |
| Trial Pit | 1.0 | Download for the Data Entry Profile for Trial Pit locations | TrialPit.hbc | 04th April 2016 |
| Window Sample | 1.0 | Download for the Data Entry Profile for Window Sample locations | WindowSample.hbc | 04th April 2016 |
| Borehole Data | 1.0 | Download for the Data Entry Profile for Borehole locations | ASTMBoreholeDataEntryProfile.hbc | 04th April 2016 |
