Component files (HBC's) cover a wide range of updates that effect HoleBASE, usually within a configuration pack but sometimes at system level too. These can cover everything from model updates, to borehole templates and many more.
To download any of these files, please put in a service request with our support team at https://apps.bentley.com/srmanager/ProductSupport with the filename in the description and a member of our support team will send a copy of the file to you.
The following downloads are sectioned up into the relevant categories.
Database model updates update the data model in someway to have further tables and fields or modifications as needed.
| Item | Version | Description | Filename | Date Added |
| Cone Penetration Testing Data Extension | 1.0 | This will extend the HBSI data model for use with CPT Data | Cone Penetration Testing Data Extension.hbc | 11th May 2016 |
| Empty Cache | 1.0 | This will clear the Database Cache | EmptyCache.hbc | 20th October 2016 |
Log templates allow for further templates to be added to the system which show data in different ways as needed. These are the non-editable versions for use without Template Studio, for these templates, please see the HBT editable versions. These logs are further broken down into the region that they apply to.
Cone Penetration Testing log | 1.0 |
Template for Cone Penetration Testing (In order to work correctly this log requires that the Cone Penetration Testing Data Extension.hbc found in the database model update section above be imported first.) | Cone Penetration Testing log.hbc | 11th May 2016 |
| Combined Template | 1.0 | Combined Template for use with the Depth Related Exploratory Hole Information table. This contains provision for a number of known location types and will also create copied versions of the standard HoleBASE SI templates with a TS prefix. | TS Logs.hbc | 24th May 2016 |
| Enhanced Borehole Log | 1.0 | An enhanced version of the default borehole, this showing additional insitu tests in particular. | Enhanced Borehole Log.hbc | 04th April 2016 |
| Enhanced Dynamic Probe Log | 1.0 | An enhanced version of the default borehole log, this showing the groundwater and abortion reason associated with the run in the footer area. | Enhanced Dynamic Probe Log.hbc | 04th April 2016 |
| Enhanced Rotary Core Log | 1.0 | An enhanced version of the default coring template, this showing an additional column for insitu test results and other information. | Enhanced Rotary Core Log.hbc | 04th April 2016 |
| Enhanced Trial Pit Log | 1.0 | An enhanced version of the default trial pit log, this showing additional insitu tests in particular. | Enhanced Trial Pit Log.hbc | 04th April 2016 |
| Enhanced Soakaway Trial Pit Log | 1.0 | An enhanced version of the default trial pit log this showing a tabular footer area and details of soakway tests. | Enhanced Soakaway Trial Pit Log.hbc | 04th April 2016 |
| Enhanced Tabular Borehole Log | 1.0 | An enhanced version of the default borehole, this showing additional insitu tests over the default HoleBASE SI template in particular. This version also includes a tabular presentation of pertinent data in the footer area. | Enhanced Tabular Borehole Log.hbc | 04th April 2016 |
| Enhanced Tabular Rotary Core Log | 1.0 | An enhanced version of the core log, this include tabular information in the footer area. | Enhanced Tabular Rotary Core Log.hbc | 04th April 2016 |
| Enhanced Tabular Trial Pit Log | 1.0 | An enhanced version of the default trial pit log, this including a tabular presenation of pertinent information in the footer area. | Enhanced Tabular Trial Pit Log.hbc | 04th April 2016 |
| Borehole Log Landscape logo | 1.0 | A copy of the standard Borehole Log shipped with HoleBASE SI, this has been edited to allow for a landscape logo to be shown in the header. | Borehole Log Landscape logo.hbc | 09th January 2017 |
| Dynamic Probe Log Landscape logo | 1.0 | A copy of the standard Dynamic Probe Log shipped with HoleBASE SI, this has been edited to allow for a landscape logo to be shown in the header. | Dynamic Probe Log Landscape logo.hbc | 09th January 2017 |
| Rotary Core Log Landscape logo | 1.0 | A copy of the standard Rotary Core Log shipped with HoleBASE SI, this has been edited to allow for a landscape logo to be shown in the header. | Rotary Core Log Landscape logo.hbc | 09th January 2017 |
| Trial Pit Log Landscape logo | 1.0 | A copy of the standard Trial Pit Log shipped with HoleBASE SI, this has been edited to allow for a landscape logo to be shown in the header. | Trial Pit Log Landscape logo.hbc | 09th January 2017 |
The following logs are only compatible with versions 1.34.0.x and later of HoleBASE.
| British Standard Percussion Drilling Log | 1.0 | Updated Borehole Log for 2018 | British Standard Percussion Drilling Log.hbc | 14th February 2018 |
| British Standard Rotary Core Log | 1.0 | Updated Rotary Core Log for 2018 | British Standard Rotary Core Log.hbc | 14th February 2018 |
| British Standard Probe Test Log | 1.0 | New Probe Test Log showing SPT blows | British Standard Probe Test Log.hbc | 14th February 2018 |
| British Standard Trial Pit Log | 1.0 | Updated Trail Pit Log for 2018 | British Standard Trial Pit Log | 14th February 2018 |
| Trial Pit Log with Photos | 1.0 | Trial Pit log including image grid for photos | Trial Pit with Photos Log | 29th November 2018 |
CPT Pore Pressure Log | 1.0 | Static Cone Penetration Test Log with Friction Ratio and Pore Pressue | CPT Pore Pressure Log.hbc | 14th February 2018 |
| Environmental Borehole Log | 2.0 | Template for Environmental Data | ASTM Environmental Borehole Log.hbc | 26th January 2018 |
| Environmental Borehole Plot | 2.0 | Template for Environmental Data | ASTM Environmental Borehole Plot.hbc | 26th January 2018 |
| Laboratory Borehole Log | 2.0 | Template for Laboratory Data | ASTM Laboratory Borehole Log.hbc | 26th January 2018 |
| Standard Borehole Plot | 2.0 | Standard Borehole Template | ASTM Standard Borehole Plot.hbc | 26th January 2018 |
| RTA Cored Drill Hole Log | 1.0 | RTA Cored Drill Hole Log.hbc | 14th February 2018 | |
| RTA Non-Core Drill Hole - Geological Log | 1.0 | RTA Non-Core Drill Hole - Geological Log.hbc | 14th February 2018 |
Header Templates are templates that can be used to display summary type data onto paper or out to PDF. These are the non-editable versions for use without Template Studio, for these templates, please see the HBT editable versions.
| Supplementary Hole Information Sheet | 1.0 | An additional tabular sheet which might summarise additional data in a daily record. Typically used as a second supplementary sheet on log output. | Supplementary Hole Information sheet.hbc | 04th April 2016 |
Master Templates are Templates that have dynamic Depth Area which uses Strip Sets to determine what is being displayed. These are further broken down into the Master Template itself and the corresponding strip sets.
| Master Template Example | 1.0 | An example of a Master Template. This includes the Strips Sets and Strips | Master Template Example.hbc | 12th January 2018 |
| Example Master Template Strip Set | 1.0 | An Example of Master Template Strip Sets | Master Template Strip Sets.hbc | 12th January 2018 |
| Example Master Template Strips | 1.0 | An Example set of Master Template Srips | Master Template Strips.hbc | 12th January 2018 |
Section Templates are templates that allow for you to draw sticks based on information that has been selected from the mapping interface within HoleBASE SI. These are only available to HoleBASE SI Professional users. These are the non-editable versions for use without Template Studio, for these templates, please see the HBT editable versions. These logs are further broken down into the region that they apply to.
| Geology Code Section Log | 1.0 | Download for a default HoleBASE SI Section Template showing Geology Code in the description. | Default Section Log with Geology Code.hbc | 04th April 2016 |
| Geology Code 2 and Samples Section Log | 1.0 | Download for a default HoleBASE SI Section Template showing Geology Code2 in the description and Sample Information. | Section Log with 2nd Geology Code and Samples.hbc | 04th April 2016 |
| Full Geology Description Section Log | 1.0 | Download for a default HoleBASE SI Section Template showing the full Geology Description in the description. | Section Log with Geology Full Description.hbc | 04th April 2016 |
| Sample Information Section Log | 1.0 | Download for a default HoleBASE SI Section Template showing Sample Information | Section Log with Samples.hbc | 04th April 2016 |
| SPT N Value Section Log | 1.0 | Download for a default HoleBASE SI Section Template showing SPT N Values. | Section Log with SPT N Value.hbc | 04th April 2016 |
| Blank Section Log | 1.0 | Download for a default blank HoleBASE SI Section Template. | Blank Section Log.hbc | 04th April 2016 |
Site Plan Templates are templates that allow for you to plot a copy of what has been selected from the mapping interface within HoleBASE SI. These are only available to HoleBASE SI Professional users. These are the non-editable versions for use without Template Studio, for these templates, please see the HBT editable versions.
| Landscape A1 | 1.0 | Download for an A1 Landscape version of the Standard HoleBASE SitePlan Template. | Landscape A1.hbc | 04th April 2016 |
| Landscape A1 No Legend | 1.0 | Download for an A1 Landscape version of the Standard HoleBASE SitePlan Template with no Legend. | Landscape A1 No Legend.hbc | 04th April 2016 |
| Landscape A3 | 1.0 | Download for an A3 Landscape version of the Standard HoleBASE SitePlan Template. | Landscape A3.hbc | 04th April 2016 |
| Landscape A3 No Legend | 1.0 | Download for an A3 Landscape version of the Standard HoleBASE SitePlan Template with no Legend. | Landscape A3 No Legend.hbc | 04th April 2016 |
| Portrait A1 | 1.0 | Download for an A1 Portrait version of the Standard HoleBASE SitePlan Template. | Portrait A1.hbc | 04th April 2016 |
| Portrait A1 No Legend | 1.0 | Download for an A1 Portrait version of the Standard HoleBASE SitePlan Template with no Legend. | Portrait A1 No Legend.hbc | 04th April 2016 |
| Portrait A3 | 1.0 | Download for an A3 Portrait version of the Standard HoleBASE SitePlan Template. | Portrait A3.hbc | 04th April 2016 |
| Portrait A3 No Legend | 1.0 | Download for an A3 Portrait version of the Standard HoleBASE SitePlan Template with no Legend. | Portrait A3 No Legend.hbc | 04th April 2016 |
Report Views are basically joins between different tables of data to allow for analysis between data. For example, a report view may join data from the geology and sample tables. These are further broken down into the region that they apply to.
| Chain of Custody | 1.0 | This Report View adds a new "Chain of Custody" item to your Statistics Reports Views within HoleBASE SI that lists all of the chain of custody information that is stored within the project and also the corresponding sample information. | ChainOfCustody.hbc | 04th April 2016 |
| Laboratory Scheduling | 1.0 | This Report View adds a new "Laboratory Schedule" item to your Statistics Reports Views within HoleBASE SI that lists all of the laboratory scheduling information that is stored within the project and also the corresponding sample information. | Lab Scheduling.hbc | 04th April 2016 |
| Contamination Summary | 1.0 | This Report View adds a new "Contamination Summary" item to your Summary Reports Views within HoleBASE SI that lists every contamination test item and their corresponding sample and location information. | ContaminationSummary.hbc | 04th April 2016 |
| Contamination Summary by Geology | 1.0 | This Report View adds a new "Contamination Summary by Geology" item to your Summary Reports Views within HoleBASE SI that lists Summarised Contamination data and their corresponding geology and location information. | Contamination Summary by Geology.hbc | 04th April 2016 |
| CPT Summary | 1.0 | This Report View adds a new "CPT Summary" item to your Summary Reports Views within HoleBASE SI. This reports the details of the CPT equipment used alongside the readings for a CPT run. | CPT Summary.hbc | 04th April 2016 |
| Geology Summary | 1.0 | This Report View adds a new "Geology Summary" item to your Summary Reports Views within HoleBASE SI . It lists each geology code found in the current selection and the top of the first instance and the base of the last instance giving an ideal summary of geology conditions across the site. | Geology Summary.hbc | 04th April 2016 |
| Location Coordinate Summary | 1.0 | This report view adds a new summary view which details the current lat long details calculated from the coordinates entered into HoleBASE SI. | Location Summary.hbc | 14th June 2016 |
| Water Strike by Summary | 1.0 | This Report View adds a revised "Water Strike by Geology" item to your Summary Reports Views within HoleBASE SI that lists all Water Strike data matched to the geology record for the Water Strike across the project. | Water Strike Summary.hbc | 04th April 2016 |
| Backfill Material Used | 1.0 | This Report View adds a revised "Backfill Material Used" item to your Summary Reports Views within HoleBASE SI that lists all of the different backfill materials used across the project and how much meterage they cover. | Backfill Material Used.hbc | 06th December 2016 |
| SPTs Crossing Multiple Geologies | 1.0 | This Report View adds a new report that shows all of the SPTs in a project that cross multiple geology boundaries. | SPT Multiple Geology.hbc | 22nd March 2018 |
| SPT Equipment Information | 1.0 | This Report View adds a revised "SPT Equipment Information" item to your Summary Reports Views within HoleBASE SI that lists all of the unique SPT hardware that is used across the project. | SPT Equipment Information.hbc | 06th December 2016 |
| Unique Geology Combinations | 1.0 | This Report View adds a revised "Unique Geology Combinations" item to your Summary Reports Views within HoleBASE SI that lists all of the different unique combinations of legend codes and geology codes across the project. | Unique Geology Combinations.hbc | 06th December 2016 |
| Chalk by Geology | 1.0 | This Report View adds a new "Chalk by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Chalk Tests and their corresponding geology and location information. | ChalkbyGeology.hbc | 04th April 2016 |
| Chiselling by Geology | 1.0 | This Report View adds a new "Chiselling by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Chiselling data and their corresponding geology and location information. | ChisellingbyGeology.hbc | 04th April 2016 |
| Classification by Geology | 1.0 | This Report View adds a new "Classification by Geology" item to your Summary Reports Views within HoleBASE SI that lists each Location wiith the sample information from the following tables and their corresponding geology information; Moisture Content, Organic Content, Grading and Particle Density. | ClassificationbyGeology.hbc | 04th April 2016 |
| Collated Contamination by Geology | 1.0 | This Report View adds a new "Collated Contamination by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Collated Contamination data and their corresponding geology and location information. | Collated Contaminate by Geology.hbc | 04th April 2016 |
| Compaction by Geology | 1.0 | This Report View adds a revised "Compaction by Geology" item to your Summary Reports Views within HoleBASE SI that lists each Location with the compaction tests and the corresponding geology information. | CompactionbyGeology.hbc | 04th April 2016 |
| Contaminate by Geology | 1.0 | This Report View adds a new "Contaminate by Geology" item to your Summary Reports Views within HoleBASE SI that lists each Location with the sample information and contaminate data matched up to the geology that this sits within. | Contaminate by Geology.hbc | 04th April 2016 |
| Coring by Geology | 1.0 | This Report View adds a new "Coring by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Coring data and their corresponding geology and location information. | CoringbyGeology.hbc | 04th April 2016 |
| Coring By Geology 2 | 1.0 | This report view adds a report view which reports all strata dissected by an individual core run. | CoringbyGeology2.hbc | 15th June 2016 |
| Coring Tables by Geology | 1.0 | This Report View adds a new "Coring Tables by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Coring data along with Fracturing, Discontinuities, Weathering and other data and their corresponding geology and location information | CoringDrillingbyGeology.hbc | 04th April 2016 |
| CPT by Geology | 1.0 | This Report View adds a revised "CPT by Geology" item to your Summary Reports Views within HoleBASE SI that lists all CPT data matched to the geology record for the CPT Depth. | CPT by Geology.hbc | 04th April 2016 |
| Dynamic Probe by Geology | 1.0 | This Report View adds a new "Dynamic Probe Tests by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Dynamic Probe Tests and their corresponding geology and location information. | DynamicProbebyGeology.hbc | 04th April 2016 |
| Geotechnical Chemistry by Geology | 1.0 | This Report View adds a new "Geotechnical Chemistry by Geology" item to your Geology Reports Views within HoleBASE SI that lists all their corresponding geology and location information. | Geotechnical Chemistry by Geology.hbc | 04th April 2016 |
| Grading by Geology | 1.0 | This Report View adds a new "Grading by Geology" item to your Summary Reports Views within HoleBASE SI that lists all of the grading information and the corresponding sample information. | gradingbygeology.hbc | 04th April 2016 |
| Grading Envelope by Geology Code | 1.0 | This Report View is an updated version of the standard Grading Envelope by Geology Code. The original allowed a grading envelope showing the minimum and maximum values for each strata to be displayed this being grouped on Geology Code. This updated version also allows grouping to take place on 2nd Geology Code, Legend Code, Geological Formation and BGS Lexicon. | GradingEnvelopes.hbc | 04th April 2016 |
| Insitu Testing by Geology | 1.0 | This Report View adds a new "Insitu Testing by Geology" item to your Geology Reports Views within HoleBASE SI that lists every insitu test and their corresponding geology and location information. Tests that have been joined include; SPT, CBR, Density, Hand Penetrometer, Permeability, Redox, Resistivity, Vane, FID, PID and Soakaway Tests. | Insitu Tests by Geology.hbc | 04th April 2016 |
| Laboratory CBR by Geology | 1.0 | This Report View adds a new "Laboratory CBR by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Laboratory California Bearing Ratio Tests and their corresponding geology and location information. | LaboratoryCBRbyGeology.hbc | 04th April 2016 |
| MCV by Geology | 1.0 | This Report View adds a new "MCV by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Moisture Content Values and their corresponding geology and location information. | MCVbyGeology.hbc | 04th April 2016 |
| MONR by Geology | 1.0 | This Report View adds a new "MONR by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Monitoring Readings and their corresponding geology and location information. | MONRbyGeology.hbc | 04th April 2016 |
| Permeability Tests by Geology | 1.0 | This Report View adds a new "Permeability Tests by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Permeability Tests and their corresponding geology and location information. | PermTestsByGeology.hbc | 04th April 2016 |
| Pipe Details by Geology | 1.0 | This Report View adds a new "Pipe Details by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Installation details and their corresponding geology and location information. | PipebyGeology.hbc | 04th April 2016 |
| Monitoring Response Zone by Geology | 1.0 | This Report View adds a new "Monitoring Response Zone by Geology" item to your Geology Reports Views within HoleBASE that shows all of the monitoring records within HoleBASE and the geologies that these records pass through. | Monitoring Reponse zone by Geology.hbc | 04th July 2018 |
| Rock Testing by Geology | 1.0 | This Report View adds a new "Rock Testing by Geology" item to your Geology Reports Views within HoleBASE SI that lists every rock test and their corresponding geology and location information. This is useful to recombine all of the ROCK table data from AGS 3.1 which has been split into multiple tables with AGS 4 and therefore HoleBASE SI. Tables that have been joined include: Aggregate Abrasion, Aggregate Crushing Value, Aggregate Elongation Index, Aggregate Flakiness, Aggregate Impact Value, Aggregate Polished Stone, Los Angeles Abrasion, Slake Durability Index, Aggregate Soundness, Aggregate Water Absorption, Dynamic, Swelling Index, Rock Porosity and Density, Point Loads, Shore Scleroscope Hardness, Tensile Strength and Rock Uniaxial Compressive Strength and Deformability. | RockTestingbyGeology.hbc | 04th April 2016 |
| SPT by Geology | 1.0 | This Report View adds a revised "SPT by Geology" item to your Summary Reports Views within HoleBASE SI that lists all SPT data matched to the geology record for the SPT Top. | SPTbyGeology.hbc | 04th April 2016 |
| SPT by Geology with Reduced Level | 1.0 | This Report View adds a revised "SPT by Geology with Reduced Level" item to your Summary Reports Views within HoleBASE SI that lists all SPT data matched to the geology record for the SPT Top with Reduced levels included for depth values. | SPTbyGeologyWithReducedLevel.hbc | 04th April 2016 |
| Samples by Geology | 1.0 | This Report View adds a revised "Samples by Geology" item to your Summary Reports Views within HoleBASE SI that lists all of the sample information within the project and its corresponding geology information. | samplesbygeology.hbc | 04th April 2016 |
| All Triaxial Tests and SPT by Geology | 1.0 | This Report View adds a new "Triaxial Tests and SPT by Geology" item to your Geology Reports Views within HoleBASE SI that lists all Triaxial Tests and all SPT tests, joined together on their corresponding geology and location information. | TriaxialvsSPTbyGeology.hbc | 04th April 2016 |
| Triaxial Effective Stress by Geology | 1.0 | This Report View adds a revised "Triaxial Effective Stress by Geology" item to your Summary Reports Views within HoleBASE SI that lists each Location with the triaxial tests and the corresponding geology information. | TriaxialEffectiveStressbyGeology.hbc | 04th April 2016 |
| Triaxial Total Stress by Geology | 1.0 | This Report View adds a revised "Triaxial Total Stress by Geology" item to your Summary Reports Views within HoleBASE SI that lists each Location with the triaxial tests and the corresponding geology information. | TriaxialTotalStressbyGeology.hbc | 04th April 2016 |
| Insitu Vane Tests by Geology | 1.0 | This Report View adds a new "Insitu Vane by Geology" item to your Geology Reports Views within HoleBASE SI that lists all vane tests and their corresponding geology and location information. | VaneTestsByGeology.hbc | 04th April 2016 |
| Water Strike by Geology | 1.0 | This Report View adds a new "Water Strike by Geology" item to your Geology Reports Views within HoleBASE SI that lists all water strikes and their corresponding geology and location information. | Water Strike by Geology.hbc | 04th April 2016 |
| Multiple Unit Contaminants | 1.0 | This Report View adds a new "Multiple Unit Contaminants" item to your validation Reports Views within HoleBASE SI that lists each contaminant that has more than one unit defined. | Multiple Unit Contaminants.hbc | 04th April 2016 |
| Missing Legend Codes | 1.0 | This Report View adds a new "Missing Legend Codes" item to your validation Reports Views within HoleBASE SI that lists each Location that has missing codes and the number of codes missing. | missing legend codes.hbc | 04th April 2016 |
| Missing Geology Records | 1.0 | A list of all gaps on geological data. | Geology Gaps.hbc | 04th April 2016 |
| Incorrect Coring Results | 1.0 | This Report View adds a new "Incorrect Coring Results" item to your validation Reports Views within HoleBASE SI. This will flag up whenever the RQD is recorded as a greater value than SCR or where SCR is greater than TCR. | Incorrect Coring Results.hbc | 04th April 2016 |
| Overlapping Geology | 1.0 | This Report View updates the existing "Overlapping Geology" item to your validation Reports Views within HoleBASE SI that lists each instance where there are instances of geologies with overlapping depths. | OverlappingGeology.hbc | 04th April 2016 |
| Coring Data Below Final Depth | 1.0 | This report view evaluates the data within the project to see if there are any Coring Data that appear below the final depth of the location as stated in the Location Details table. | CoringBelowFinalDepth.hbc | 06th December 2016 |
| Discontinuity Data Below Final Depth | 1.0 | This report view evaluates the data within the project to see if there are any Discontinuities that appear below the final depth of the location as stated in the Location Details table. | DiscontinuitiesBelowFinalDepth.hbc | 06th December 2016 |
| Sample Data Below Final Depth | 1.0 | This report view evaluates the data within the project to see if there are any Samples that appear below the final depth of the location as stated in the Location Details table. | SamplesBelowFinalDepth.hbc | 06th December 2016 |
| SPT Data Below Final Depth | 1.0 | This report view evaluates the data within the project to see if there are any SPT tests that appear below the final depth of the location as stated in the Location Details table. | SPTBelowFinalDepth.hbc | 06th December 2016 |
| Backfill Depth to Final Depth | 1.0 | This report view evaluates the data within the project to see if there are any locations where the backfill does not go all the way to the base of the hole. | Backfill Depth to Final Depth.hbc | 02nd February 2017 |
| Depth Related Hole Information to Final Depth | 1.0 | This report view evaluates the data within the project to see if there are any locations where the depth related exploratory hole inforamtion does not go all the way to the base of the hole. | Depth Related Hole Information to Final Depth.hbc | 02nd February 2017 |
| Hole Diameter to Final Depth | 1.0 | This report view evaluates the data within the project to see if there are any locations where the hole diameter does not go all the way to the base of the hole. | Hole Diameter to Final Depth.hbc | 02nd February 2017 |
| Overlapping Backfill | 1.0 | This report view evaluates the data within the project to see if there is any backfill data that overlaps. | Overlapping Backfill.hbc | 02nd February 2017 |
| Overlapping Pipe | 1.0 | This report view evaluates the data within the project to see if there is any pipe data that overlaps. | Overlapping Pipe.hbc | 02nd February 2017 |
| Backfill Gaps | 1.0 | This report view evaluates the data within the project to see if there are any gaps in the backfill data for each lcoation. | Backfill Gaps.hbc | 02nd February 2017 |
| Pipe Gaps | 1.0 | This report view evaluates the data within the project to see if there are any gaps in the backfill data for each lcoation. | Pipe Gaps.hbc | 02nd February 2017 |
| Chiseling Duration Checker | 1.0 | Ensures that Chiseling duration is no longer than 0.5m per hour. | Chiseling Duration Checker.hbc | 21st September 2018 |
| Depth Exploratory Information outside of Date Range | 1.0 | Ensures that Depth Related Information falls within the Start and End dates of the location. | Depth Exploratory Information outside of Date Range.hbc | 21st September 2018 |
| Discontinuity Depths Consistency | 1.0 | Ensures that Discontinuity Base Depth is always more than Depth Top. | Discontinuity Depths Consistency.hbc | 21st September 2018 |
| Fracture Spacing Gaps for Rotary Core | 1.0 | Ensures that a corresponding record in the Fracture Spacing table exists for Rotary Core Drilling. | Fracture Spacing Gaps for RC.hbc | 21st September 2018 |
| Geology and Weathering Record Checker | 1.0 | Ensures that a corresponding record in the Weathering table exists for each Geology. | Geology and Weathering Record Checker.hbc | 21st September 2018 |
| Location Date Checker | 1.0 | Ensures that the end date for a location is greater than the start date. | Location Date Checker.hbc | 21st September 2018 |
| Location Type Consistency | 1.0 | Ensures that there is a record in the Depth Related Hole Information table for every drilling type in location details. | Location Type Consistency.hbc | 21st September 2018 |
| Missing Sample Blows and Recovery | 1.0 | Ensures that there is a record in the Sample table for blows and recovery. | Missing Sample Blows and Recovery.hbc | 21st September 2018 |
| Progress to Final Depth Checker | 1.0 | Ensures that there is a record in the Progress by Time table for the whole depth of the location. | Progress to Final Depth Checker.hbc | 21st September 2018 |
| Samples outside of Date Range | 1.0 | Ensures that there is no samples are taken outside of the Location Date Range. | Samples outside of Date Range.hbc | 21st September 2018 |
| SPT Greater than Final Depth | 1.0 | Ensures that there is no SPT results below the final depth of the location. | SPT Greater than Final Depth.hbc | 21st September 2018 |
| SPT Results over Maximum | 1.0 | Ensures that no SPT result is over 50 in soil and over 100 in rock. | SPT Results over Maximum.hbc | 21st September 2018 |
| Trial Pit Blank Dimensions Checker | 1.0 | Ensures that a result exists for trial pit dimensions in trial pit locations. | Trial Pit Blank Dimensions Checker.hbc | 21st September 2018 |
| Trial Pit Blank Orientation Checker | 1.0 | Ensures that a result exists for trial pit orientations in trial pit locations. | Trial Pit Blank Orientation Checker.hbc | 21st September 2018 |
| Water Strike Consistency | 1.0 | Ensures that the correct results are present in the water strike details table. | Water Strike Consistency.hbc | 21st September 2018 |
| Water Strikes outside of Date Range | 1.0 | Ensures that water strike records are recorded inside of the location date range. | Water Strikes outside of Date Range.hbc | 21st September 2018 |
| WDEP Records Past Monitoring Distance | 1.0 | Ensures that any WDEP records in the Monitoring Readinds table are not past the Monitoring Point Distance. | WDEP Records Past Monitoring Distance.hbc | 21st September 2018 |
| Window Sampling Child Record Checker | 1.0 | Ensures that Window Sampling Records exist for Window Sample location types. | Window Sampling Child Record Checker.hbc | 21st September 2018 |
The default mapping symbols are the images used to show locations on the map within HoleBASE SI.
| Default Location Types | 1.0 | The standard HoleBASE SI location type picklist images used on the mapping. | Default_Active_LocationType.zip | 04th April 2016 |
| Default Active Location Types | 1.0 | The standard HoleBASE SI location type picklist images used on the mapping and shown when an item is selected. | Default_Location_Types.zip | 04th April 2016 |
The picklist symbols are the images used to show information everywhere from the grids, to your templates within HoleBASE SI.
| Project | 1.0 | The standard HoleBASE SI project picklist images including Category and Status. | Project.zip | 04th April 2016 |
| Legend | 1.0 | The standard HoleBASE SI legend picklist images used for geology information. | Legend.zip | 04th April 2016 |
| Pipe | 1.0 | The standard HoleBASE SI pipe picklist images used for installation information. | PipeType.zip | 04th April 2016 |
| Backfill | 1.0 | The standard HoleBASE SI backfill picklist images used for backfill information. | Backfill_LegendCode.zip | 04th April 2016 |
| Location Status | 1.0 | The standard HoleBASE SI status picklist images used for location information. | LocationStatus.zip | 04th April 2016 |
| USCS Geologies | 1.0 | The standard ASTM HoleBASE SI picklist images used for geology information. | USCS.zip | 30th November 2016 |
These hatches are for use with the AutoCAD Civils Extension
| USGS Hatches and Styles | 1.0 (Only compatible with 1.34.2.x) | Contains a set of new USGS Legend Code hatches and new Styles | USGSHatches.hbc | 22nd August 2019 |
Point Symbols are the images used on the templates to show a record or data at a certain depth.
| Blue Water Strike Image | 1.0 | This file will replace the standard Black Water Strike Image with a Blue one to mirror what was present in HoleBASE 3.1 |
WaterstrikeBlue inverted.hbc | 13th June 2017 |
New paper sizes can be added to HoleBASE SI to allow for more options when outputting your data with templates, sections, site plans and more.
| A0 | 1.0 | This will add a new A0 paper size to HoleBASE SI. | PaperSize_A0.hbc | 06th July 2016 |
| Ledger | 1.0 | This will add a new Ledger (17in x 11in) paper size to HoleBASE SI. | Ledger.hbc | 06th July 2016 |
| ANSI C | 1.0 | This will add a new ANSI C (17in x 22in) paper size to HoleBASE SI. | PaperSize_ANSI_C-unsigned.HBC | 06th July 2016 |
| ANSI D | 1.0 | This will add a new ANSI D (22in x 34in) paper size to HoleBASE SI. | PaperSize_ANSI_D-unsigned.HBC | 06th July 2016 |
| ANSI E | 1.0 | This will add a new ANSI E (34in x 44in) paper size to HoleBASE SI. | PaperSize_ANSI_E-unsigned.HBC | 06th July 2016 |
