A configuration pack is the part of the application that holds all of the components within. For example, a configuration pack may contain many of the following; Sections, Site Plans, Model Changes, Import / Export mappings or Log Templates. These are generally set up for use per region on this website.
To download any of these files, please put in a service request with our support team at https://apps.bentley.com/srmanager/ProductSupport with the filename in the description and a member of our support team will send a copy of the file to you.
| Item | Version | Description | Filename | Date Added |
| BS Configuration Pack | 3.0 | The standard HoleBASE SI configuration pack for the United Kingdom and in particular the AGS 4 format. Updated Logs with new Combined Log | British Standard - Default.hbp |
28th November 2018 |
| ASTM- Imperial Configuration Pack | 2.0 | The standard HoleBASE SI configuration pack for the United States. (Imperial Units) | ASTM - Default.hbp | 15th January 2018 |
| ASTM - Metric Configuration Pack | 2.0 | A variation of the standard HoleBASE SI configuration pack for the United States, however this has been setup with metric units instead of the imperial units used in the standard ASTM Configuration Pack. | ASTM - Metric.hbp | 15th January 2018 |
| Australian Default | 1.0 | A Configuration Pack designed for Australian Users. It is designed with the RMS format in mind. Updated CSV mapping for Field Geological Descriptions Rock and Soil | Australian - Default.hbp | 28th February 2018 |
| HS2 Config Pack | 1.0 | A Variation of the Standard HoleBASE SI configuration pack which contains HS2 approved components | HS2.hbp | 17th November 2017 |
