The default templates are the sheets that can be opened within Excel, then have data entered within them that relates to the type of template and then the data can be exported into AGS format with the use of KeyAGS.
To download any of these files, please put in a service request with our support team at https://apps.bentley.com/srmanager/ProductSupport with the filename in the description and a member of our support team will send a copy of the file to you.
| Item | Version | Description | Filename | Date Added |
| Borehole Entry Sheet | 1.0 | Default Data Entry Sheet for Borehole Data in AGS 3.1 format. | Borehole Entry Sheets.xlt | 04th April 2016 |
| Dynamic Probe Entry Sheet | 1.0 | Default Data Entry Sheet for Dynamic Probe Data in AGS 3.1 format. | Dynamic Probe Entry Sheets.xlt | 04th April 2016 |
| Trial Pit Entry Sheet | 1.0 | Default Data Entry Sheet for Trial Pit Data in AGS 3.1 format. | Trial Pit Entry Sheets.xlt | 04th April 2016 |
