These files can be opened by opening Template Studio and then selecting the Load option. Once saved in Template Studio, they will be available for use within HoleBASE.
To download any of these files, please put in a service request with our support team at https://apps.bentley.com/srmanager/ProductSupport with the filename in the description and a member of our support team will send a copy of the file to you.
The following templates can be opened within Template Studio. These are further broken down into the types of template.
A borehole template is a template that allows for you to plot data from any location type onto a PDF or paper output. The difference between these files and the HoleBASE SI ones are that these ones are editable within Template Studio. These are further broken down into the regions that they are applicable too.
Item | Version | Description | Filename | Date Added |
Percussion Drilling Log | 2.0 | An updated version of the new British Standard Borehole Log compatible with the Yellow Book of drilling.(Only compatible with 1.34.0.x or 1.34.1.x) | British Standard Percussion Drilling Log.hbt | 08th April 2018 |
Rotary Core | 2.0 | An updated version on the new Rotary Core Log compatible with the Yellow Book of drilling(Only compatible with 1.34.0.x or 1.34.1.x) | British Standard Rotary Core Log.hbt | 08th April 2018 |
Probe Test | 2.0 | An updated version of the new Probe Test Log compatible with the Yellow Book of drilling. (Only compatible with 1.34.0.x or 1.34.1.x) | British Standard Probe Test Log.hbt | 08th April 2018 |
Trial Pit | 2.0 | An updated version of the new Trial Pit log compatible with the Yellow Book of drilling. (Only compatible with 1.34.0.x or 1.34.1.x) | British Standard Trial Pit Log.hbt | 08th April 2018 |
Borehole Log | 1.0 | Copy of the Standard Borehole Log found within HoleBASE SI. | TS Borehole Log.hbt | 04th April 2016 |
Combined Log | 1.0 | A combined template that uses the Depth Related Exploratory Hole Information table to detail a change in log template. Borehole and Rotary Core are supported by default. | TS Combined Log.hbt | 04th April 2016 |
Cone Penetration Testing Log | 1.0 |
This is an editable version of the log file found here (In order to work correctly this log requires that the Cone Penetration Testing Data Extension is imported first) | Cone Penetration Testing Log.hbt | 11th May 2016 |
Dynamic Probe Log | 1.0 | Copy of the Standard Dynamic Probe log found with HoleBASE SI. | TS Probe Log.hbt | 04th April 2016 |
Rotary Core Log | 1.0 | Copy of the Standard Rotary Core log found within HoleBASE SI. | TS Rotary Core Log.hbt | 04th April 2016 |
Trial Pit Log | 1.0 | Copy of the Standard Trial Pit log found within HoleBASE SI. | TS Trial Pit Log.hbt | 04th April 2016 |
Trial Pit Photo Log | 1.0 | Standard Trial Pit log found within HoleBASE SI but with added Photo area. | Trial Pit With Images.hbt | 04th April 2016 |
Dynamic Probe Log | 1.0 | Copy of the Standard Dynamic Probe log found within HoleBASE SI. | DPLog.hbt | 04th April 2016 |
CPT Log | 1.0 | Copy of the Standard CPT Pore Pressure log found within HoleBASE SI. | TS CPT Pore Pressure Log.hbt | 04th April 2016 |
Borehole Log Landscape logo | 1.0 | A copy of the standard Borehole Log shipped with HoleBASE SI, this has been edited to allow for a landscape logo to be shown in the header. | Borehole Log Landscape logo.hbt | 09th January 2017 |
Dynamic Probe Log Landscape logo | 1.0 | A copy of the standard Dynamic Probe Log shipped with HoleBASE SI, this has been edited to allow for a landscape logo to be shown in the header. | Dynamic Probe Log Landscape logo.hbt | 09th January 2017 |
Rotary Core Log Landscape logo | 1.0 | A copy of the standard Rotary Core Log shipped with HoleBASE SI, this has been edited to allow for a landscape logo to be shown in the header. | Rotary Core Log Landscape logo.hbt | 09th January 2017 |
New Trial Pit Log with Photos | 2.0 | An updated Trial Pit Log with photos for 2018 (compatible with 1.34.0.x and 1.34.1.x only) | Trial Pit with Photos Log.hbt | 29th November 2018 |
Trial Pit Log Landscape logo | 1.0 | A copy of the standard Trial Pit Log shipped with HoleBASE SI, this has been edited to allow for a landscape logo to be shown in the header. | Trial Pit Log Landscape logo.hbt | 09th January 2017 |
Environmental Borehole Log | 1.0 | Copy of the Standard Default ASTM Envirnomental Borehole Log shipped with HoleBASE SI. | ASTM Environmental Borehole Log.hbt | 04th April 2016 |
Environmental Borehole Plot | 1.0 | Copy of the Standard Default ASTM Envirnomental Borehole Plot shipped with HoleBASE SI. | ASTM Environmental Borehole Plot.hbt | 04th April 2016 |
Standard Borehole Log | 1.0 | Copy of the Standard Default ASTM Standard Borehole Log shipped with HoleBASE SI. | ASTM Standard Borehole Plot.hbt | 04th April 2016 |
Laboratory Borehole Log | 1.0 | Copy of the Standard Default ASTM Laboratory Borehole Log shipped with HoleBASE SI. | ASTM Laboratory Borehole Log.hbt | 04th April 2016 |
A Master Template differs from standard Borehole Logs Templates in that the depth related area contains a dynamic strip column which is used with Strip Sets to change what is displayed. The difference between these files and the HoleBASE SI ones are that these ones are editable within Template Studio.
Example Master Template Log | 1.0 | An Example Editable Master Template | Example Master Template.hbt | 12th January 2018 |
Example Master Template Strips | 1.0 | An Example Set of Editable Strips for Master Template | Example TS Master Template Strips.hbc | 12th January 2018 |
A strip template is a template that allows for you to plot data from any location type onto a Section template. The difference between these files and the HoleBASE SI ones are that these ones are editable within Template Studio. These are further broken down into the region that they are applicable too.
2nd Geology Code | 1.0 | Strip designed to be used in a Borehole Log template which shows the Geology Code 2 field in a Graphics Bar display. | 2nd Geology Code.hbt | 13th March 2018 |
Max Arsenic | 1.0 | Strip designed to be used in a Borehole Log template which shows the Maximum Arsenic value in a text format. | Arsenic Max.hbt | 13th March 2018 |
Coring Information | 1.0 | Strip designed to be used in a Borehole Log template which shows the Coring data (TCR, RQD and SCR) in text box formats. | Coring.hbt | 13th March 2018 |
Flush Return | 1.0 | Strip designed to be used in a Borehole Log template which shows the Flush Return in a line graph. | Flush Return Line Graph.hbt | 13th March 2018 |
Fracture Index | 1.0 | Strip designed to be used in a Borehole Log template which shows the Fracture Index in a text box format. | Fracture Index.hbt | 13th March 2018 |
Fracturing Discontinuity Set Reference | 1.0 | Strip designed to be used in a Borehole Log template which shows the Fracturing Discontinuity Set Reference in a text box format. | Fracturing Discontinuity Set Reference strip.hbt | 13th March 2018 |
Geochemistry | 1.0 | Strip designed to be used in a Borehole Log template which shows the Geochemistry data including ACO2, AS, CACO3, CL, CO2, LOI, NO3, OGM, pH, REDOX, TDS, TS, WMG, WS. | Geochemistry Strip.hbt | 13th March 2018 |
SPT Bar Chart | 1.0 | Strip designed to be used in a Borehole Log template which shows the SPT Blow Count information in a bar chart format. Note that a custom field (SPT Depth Base) is required for this bar chart to function. This is included in the attached zip file. | SPT Bar Chart.zip | 13th March 2018 |
Stratum Description | 1.0 | Strip designed to be used in a Borehole Log template which shows the Stratum Description using the Description Bar. | Stratum Description strip.hbt | 13th March 2018 |
SPT - Strip | 1.0 | Copy of the Standard Default ASTM SPT Strip used with the Section Templates above | SPT Strip.hbt | 04th April 2016 |
Water Level - Strip | 1.0 | Copy of the Standard Default ASTM Water Level Strip used with the Section Templates above | Water Level Strip.hbt | 04th April 2016 |
A section template is a template that allows for you to plot data defined within a strip onto a PDF or paper output. The difference between these files and the HoleBASE SI ones are that these ones are editable within Template Studio.
SPT - Legal | 1.0 | Copy of the Standard Default ASTM SPT Legal Section shipped with HoleBASE SI. | SPT Legal.hbt | 04th April 2016 |
SPT - Letter | 1.0 | Copy of the Standard Default ASTM SPT Letter Section shipped with HoleBASE SI. | SPT Letter.hbt | 04th April 2016 |
Water Level - Legal | 1.0 | Copy of the Standard Default ASTM Water Level Legal Section shipped with HoleBASE SI. | Water Level Legal.hbt | 04th April 2016 |
Water Level - Letter | 1.0 | Copy of the Standard Default ASTM Water Level Letter Section shipped with HoleBASE SI. | Water Level Letter.hbt | 04th April 2016 |
A Civils section template is a template that allows for you to plot data defined within a strip into the Civils Extension. The difference between these files and the HoleBASE SI ones are that these ones are editable within Template Studio. These are further broken down into the region that they are specific too.
Blank Section | 1.0 | Download for the section template for use with the below strips. | BlankSection.hbt | 04th April 2016 |
CPT Geology Strip | 1.0 | Download for a strip that shows CPT and Geology data. | CPTGeologyCodeStrip.hbt | 04th April 2016 |
Geology Code Strip | 1.0 | Download for a strip that shows Geology data. | GeologyCodeStrip.hbt | 04th April 2016 |
Geology Code Strip 2 | 1.0 | Download for a strip that shows Geology 2 data | GeologyCodeStrip2.hbt | 04th April 2016 |
Legend Code Strip | 1.0 | Download for a strip that shows Geology Legend data. | LegendCodeStrip.hbt | 04th April 2016 |
SPT N Value Strip | 1.0 | Download for a strip that shows SPT and Geology data. | SPTNValue Strip.hbt | 04th April 2016 |
Geol and Water Levels Section | 1.0 | Section for use with the below Geol and Water Levels Strip | ASTM Civil Section Geol with Water Levels.hbt | 14th July 2016 |
Geol and Water Levels Strip | 1.0 |
Strip that shows Geology code information along with the water level entered into an ASTM set up project. *Requires KNX_Water_Strike.dwg, KNX_Water_Strike_Filled.dwg and KNX_Water_Strike_Filled.dwg | ASTM Civil Strip Geol with Water Levels.hbt | 14th July 2016 |
Geol 2 and Water Levels Section | 1.0 | Section for use with the below Geol 2 and Water Levels Strip | ASTM Civil Section Geol 2 with Water Levels.hbt | 14th July 2016 |
Geol 2 and Water Levels Strip | 1.0 |
Strip that shows Geology code 2 information along with the water level entered into an ASTM set up project. *Requires KNX_Water_Strike.dwg, KNX_Water_Strike_Filled.dwg and KNX_Water_Strike_Filled.dwg. | ASTM Civil Strip Geol 2 with Water Levels.hbt | 14th July 2016 |
Geology Legend and Water Levels Section | 1.0 | Section for use with the below Geology Legend and Water Levels Strip | ASTM Civil section Legend with Water strikes.hbt | 14th July 2016 |
Geology Legend and Water Levels Strip | 1.0 |
Strip that shows Geology Legend information along with the water level entered into an ASTM set up project. *Requires KNX_Water_Strike.dwg, KNX_Water_Strike_Filled.dwg and KNX_Water_Strike_Filled.dwg. | ASTM Civil Strip Legend with Water Levels.hbt | 14th July 2016 |
USCS and Water levels Section | 1.0 | Section for use with the below USCS and Water Levels Strip | ASTM Civil Section USCS with Water Levels.hbt | 14th July 2016 |
USCS and Water levels Strip | 1.0 |
Strip that shows USCS information along with the water level entered into an ASTM set up project. *Requires KNX_Water_Strike.dwg, KNX_Water_Strike_Filled.dwg and KNX_Water_Strike_Filled.dwg. | ASTM Civil Strip USCS with Water Levels.hbt | 14th July 2016 |
A site plan template is a template that allows for you to plot data defined within the mapping interface within HoleBASE SI and plot this onto a PDF or paper output. The difference between these files and the HoleBASE SI ones are that these ones are editable within Template Studio. These are further broken down based on the region that they are specific too.
Default Site Plan Template | 1.0 | Copy of the Standard Default A4 Site plan shipped with HoleBASE SI. | Default HBSI SitePlan.hbt | 04th April 2016 |
SitePlan - Legal | 1.0 | Copy of the Standard Default ASTM Legal SitePlan shipped with HoleBASE SI. | SitePlan Legal.hbt | 04th April 2016 |
SitePlan - Letter | 1.0 | Copy of the Standard Default ASTM Letter Siteplan shipped with HoleBASE SI. | SitePlan Letter.hbt | 04th April 2016 |
