An adapted version of the Excel schedule report for laboratory scheduling. It can be used as a standalone spreadsheet or as part of the HoleBASE SI Extension for Microsoft Excel. This version reports samples by the 2nd Geology Code and includes an elevation column.
To Load this report select the Load button from the "Reports Selection Window" within the Excel Extension and then select the file downloaded using the link below.
This report is based off of the original report which can be found here.
Please contact the support team and request for the 'Schedule Report revised.xlsm' file.
