Groundwater Monitoring Readings
Description
A scatter graph plot which shows the results from long term monitoring for groundwater. The template is setup to prefilter out other types of monitoring reading.
This template can be further adjusted in the Design Mode of the Excel Extension. A filter could be introduced to filter on time, for example. Similarly, hidden columns on the template report out the readings as text results. These could be exposed should they be preferred in the output although some adjustment of the graph header may be required.
Instructions
To Load this report select the Load button from the "Reports Selection Window" within the Excel Extension and then select the file downloaded using the link below.
Download:
Please contact the support team and request for the 'GroundwaterMonitoringreadings.xlsm' file.
