Excel Extension Reports
An Excel Extension report is a template that can be opened within the Excel Extension and run to report a variety of data. For example, the Groundwater Monitoring Readings report is used to get out all of the monitoring data regarding groundwater out of HoleBASE and into a spreadsheet. The templates may also include other data or components which will be detailed on each page as appropriate.
Instructions
To download any of these files, please put in a service request with our support team at https://apps.bentley.com/srmanager/ProductSupport with the filename in the description and a member of our support team will send a copy of the file to you.
Downloads
The following downloads are sectioned up into the relevant regions.
British Standard
ItemLink
Geology Layer Order with Pivot ExampleHere
Groundwater Monitoring ReadingsHere
Insitu Pocket Penetrometer and Hand Vane Readings by DepthHere
Insitu Pocket Penetrometer and Hand Vane Readings by ElevationHere
Laboratory Schedule - includes 2nd Geology Code and ElevationHere
Laboratory Schedule - includes Geology CodeHere
Sample Count By Geology With Pivot TablesHere
ASTM
ItemVersionDescriptionFilenameDate Added
SPT Depth plot1.0Report View that shows SPT records and can be used with the Excel Extension.SPTvsDepthPlotASTMConfigPack.hbc04th April 2016
Sample Summary1.0Excel Extension report for a summary of sample data.Sample Summary ASTM Configuration Pack.hbc03rd April 2017
Pivot Tables
Geology Layer Order1.0A template showing the order of the geology in your project.Geology Layer Order.hbcJuly 10th 2017
Geology Summary Using Pivot Tables1.0A template that show the summary of the geology across your project in a pivot table.Geology Summary Using Pivot Tables.hbcJuly 10th 2017
Histogram Example Using Pivot Tables1.0A template that shows you how you can create histograms through the use of pivot tables.Histogram Example Using Pivot Tables.hbcJuly 10th 2017
Sample Counts Using Pivot Tables1.0A template that shows how samples can be counted in various ways using pivot tables.Sample Counts Using Pivot Tables.hbcJuly 10th 2017
