Boring logs and profiles are the core of gINT reporting, but using these two report styles, you can do a number of things.
- [[Chart Particle Size Distribution as Stacked Bars]]
- [[Clip Graphic Columns]]
- [[Display Fence Reports in 3-D]]
- [[Display Multiple Column Fence Posts]]
- [[Display Multiple-Column Fence Posts on Profile Report]]
- [[Display Text in Newspaper-style Columns]]
- [[Fill Under a Plot vs. Depth Line]]
- [[Indicate Extents of Detail Descriptions]]
- [[Place Site Maps on Logs and Fences]]
- [[Plot CPT Data]]
- [[Plot Fence Profiles along Custom Baselines or Alignments]]
- [[Plot Slope Inclinometer Results]]
- [[Print Range Lines Indicating Range Covered by a Description]]
- [[Repeat Layer Description When Layer Splits Between Pages]]
- [[Report Text in Newspaper-style Columns]]
- [[Show Interbedded Material Graphics]]
- [[Specify Material Symbol Colors in Input]]
- [[Use Component Descriptions]]
