Add or Delete a Field in the Project or Data Template - Short Videos
 Product(s):gINT Logs, gINT Professional, gINT Professional Plus
 Version(s):N/A
 Environment: N/A
 Area: Project Database
 Subarea: Datatemplate
 Original Author:Kathleen Holcomb, Bentley Technical Support Group
How do I add a new field to a project or data template?
A new field can be added to a project in INPUT or in DATA DESIGN>Project Database.  It is easier to add a new field in INPUT but there are more options available in DATA DESIGN.
Data Templates can be modified in DATA DESIGN only.
How can I modify the properties of a field?  When I open
the field properties in Input everything is grayed out.
Once a field has data it can only be modified in DATA DESIGN.
How do I delete a field from a project or data template?
Deleting a field can only be done in DATA DESIGN.
Two Short Videos:
This one demonstrates adding a field in INPUT:communities.bentley.com/.../269564.aspx .
This one shows how to add a new field, add a caption, and delete a field in DATA DESIGN: communities.bentley.com/.../269565.aspx.
