| Product(s): | gINT Professional, gINT Professional Plus | ||
| Version(s): | N/A | ||
| Area: | Report-Fence | ||
| Subarea: | |||
| Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
A variable legend entity creates a legend displaying the material, sampler, well or other symbols in use all the boreholes on a fence report. This is a useful visual aid on a report. The legend is called variable because the set of symbol boxes that appears will vary from fence to fence, depending on which symbols are in use.
Note: This exercise requires the use of training.GPJ project and training.GLB library available from: download.aspx. Instructions for unzipping and setting up these files is on: using gint downloaded examples.aspx.
Go to REPORT DESIGN->Fences.
In the object selector select SIMPLE FENCE (or FINAL SIMPLE FENCE if SIMPLE FENCE is missing or incomplete).
Select File->Copy Page. Enter the following, then click OK:
| Field | Value |
| Page Name to Copy To | SIMPLE FENCE WITH LEGEND |
| Set Current Page To | First in Copy To List |
In the Data Frame tab, enter the following settings:
| Field | Value | Comments |
| Frame Y | 0.95 | Elevates the frame bottom by .45" to make room for the legend. |
| Frame Height | 5.25 | Shortens the frame by .25" so it doesn't run into the header. |
Click OK to save the property changes.
Double-click on the ‘Distance Along Baseline (ft)’ entity. The TEXT PROPERTIES window opens.
In the Main tab, enter the following, then click OK:
| Y | 0.7 | Elevates the text entity by .6" to keep it just beneath the elevated data frame. |
Select Fence->Variable Legend. The VARIABLE LEGEND dialog box appears.
Enter the following values:
| Field with Data | <<LITHOLOGY.Graphics>> | The data source will be the Graphic field in the LITHOLOGY table. Use the Data Tool. |
| Symbol Type | Material Graphics | The legend will collect all material symbols used in the fence report. |
| Number of Rows | 1 | We use a single-row legend to avoid having to compress the data frame too much. |
| Row Spacing | 0.4 | Ignored in a single-row legend. |
| Number of Columns | 10 | A maximum of 10 symbols can be displayed. To increase this we would have to narrow the column spacing or add a row. |
| Column Spacing | 1 | Distance from the start of one symbol to the start of the next. Can also be thought of as column width. |
| Rectangle Height | 0.4 | Rectangle height of each symbol. |
| Rectangle Width | 0.2 | |
| Gap between Descriptions and Rectangles | 0.05 | Distance from the right edge of each rectangle to the left edge of its description. |
| Text Height | 0.08 | Character size of description text. |
| X | 0.05 | Alignment point is .05" to right of the report border. |
| Y | 0.5 | Alignment point is .5" above the report border. This allows room for the .4" high graphic rectangles and a reasonable amount of text. |
Click OK to save the legend properties.
Go to OUTPUT->Fences, select training.gpjand preview the report. (Cancel the User Report Variables window if desired.) The report appears as shown:
Close the preview.
Variable Graphic Log Report Legend: communities.bentley.com/.../12406.variable-graphic-log-report-legend.aspx
Variable Graphic Legend Showing All Material and Sampler Graphics Used in a Project: 12419.variable graphic legend showing all material and sampler graphics used in a project.aspx
