| Product(s): | gINT Professional Plus | ||
| Version(s): | V8i SELECTseries 1 and later | ||
| Area: | Data Entry | ||
| Subarea: | N\A | ||
| Original Author: | Kathleen Holcomb, Bentley Technical Support Group and Katie Aguilar, Product Specialist | ||
gINT Coordinate Conversion provides capabilities to convert between projected (east/north) and geographic (longitude/latitude) coordinates. The gINT Professional Plus license includes a coordinate conversion library. This facility allows automatic conversion between different coordinate systems. This is the same library that is shipped with other coordinate aware Bentley products (MicroStation, InRoads, Bentley Map, etc.). This allows your gINT Professional Plus .gpj or enterprise project to interact with ArcGIS, Google Earth and Bentley GeoWeb Publisher, among other geo applications.
Note: You will need a license for gINT Professional Plus to use these features.
For the selected coordinate system, gINT will automatically calculate either WGS84 latitude and longitude from north and east values, or the other way around. Follow these steps to implement this:
If you enter latitude and longitude, gINT will calculate the northing and eastings.
If you enter both North and East, and WGS84 Latitude and WGS84 Longitude, gINT will convert from North and East, overwriting the values in WGS84 Latitude and Longitude.
When outputting a fence diagram or site map from multiple projects in an Enterprise database, if the coordinate systems are different, the program will determine the UTM zone at the center of all the boreholes and project all the coordinates to that zone. This ensures that the relative positions of the boreholes are as accurate as possible. This facility is available in Enterprise mode only.
Yes, with the Coordinate Converter tool. You can convert between 2 different systems, entering either east/north or lat/long data and getting the results in either north/east or lat/long. It will also convert between feet and meters.
If your coordinate system is not listed you can add it using Bentley Map. Download this PowerPoint presentation for information on how to do this.
Yes. In INPUT, on the menu bar, select Tools Projected Systems from Latitude and Longitude. This will give you a list of all projected systems that encompass the specified lat and long.
Select a system and click Details for Selected System... for more information.
For more information, see HelpIndex
Coordinate Conversion (input).
