Getting started with designing schedule report in KeyLAB
This guide will take you over the steps to design the sheets used for schedule reports in KeyLAB. If you don't have the tool or how to use them follow the link below to the main guide.
Back to the main Guide
Step through the guide section by section and you will have everything you need to create a schedule report sheet.
Intro to Design
https://vimeo.com/542646716
Header Design
https://vimeo.com/542647397
Location and Sample information Design
https://vimeo.com/542652313
Test Design
https://vimeo.com/542651174
