Working from home with gINT
To ensure a smooth transition of work and effectiveness of your daily workflows with gINT we have assembled this wiki to help ensure a smooth transition of work from home with gINT applications.
When working remotely, the best practice is to send a company issued laptop or access remotely.
If you are accessing files from a laptop at home and your gINT files (project, library, datatemplate) are located on a company server you would need VPN access.
The user may experience slowness or a perceived lag in performance. The perceptions may be caused due to a variety of non-gINT hurdles such as Wi-Fi bandwidth, VPN bandwidth, etc. An alternative would be to copy your gINT files locally (project, library, datatemplate).
Machine requirements
There are several options to work remotely. You may decide to install the software on your home computer.
We Recommend Windows 10 Pro with all current updates and a minimum of 4GB Ram.
Currently supported is Windows 10 Pro 64-bit.
Downloading Software
All Bentley software is downloaded from the Bentley Software Downloads pages: https://softwaredownloads.bentley.com/
General download and installation directions are available here.
Accessing Product Documentation
How do I find out who my site Administrator(s) are?
Your organization can have one or more Administrators who can assist with Bentley license management, downloads, assigning permission, etc. A list of your Administrators can be seen by going to https://connect.bentley.com. Below the Welcome Banner, click on the 'How are you CONNECTED?' link; you will find a list of your site Administrators in the “Administrators” tab (with email addresses)
Resolving licensing issues
How to Get Help
Please check this video presentation that explains the effective workflow for using gINT at home or remotely.
