KeyLAB Setup and Installation
Licencing
For set up there are a number of steps to think about. first the licensing
Make sure you know which licensing you will be using and if you have any concerns please contact your sales representative or our support team.
Connect Installation or transition
Set up the KeyLAB software.
KeyLAB - Initial Configuration
KeyLAB - Installing SQL Express
KeyLAB - Setting up the SQL Database
For articles on this subject, see the Table of Contents on the left or use the search bar above.
