KeyLAB Schedule Designer
Schedule Report and Importing
This guide is going to talk about how to use and create a schedule report for generating a report or create an import for a KeyLAB schedule.
Intro to schedule reports,
https://vimeo.com/542641702
Below is a simple template example as a starting point, to request the tool you will need to contact our support team.
Schedule-Report-Example.xlsm
Getting started with designing schedule report in KeyLAB
This guide will help to start off creating a schedule report for either input or export
Follow the link to the step by step guide
Using an export schedule report
This will guide you on how to set up the template you have created as an export to be used to report the schedule.
https://vimeo.com/542654216
Using an Import schedule
This guide will show how to create an import schedule and how to import it.
https://vimeo.com/542654942
