KeyLAB Designer and Adminstrator
The following videos will explain how to get started with KeyLAB, in this case for general users who do need to know how to administer the system.
How to Make Cosmetic Changes to KeyLAB Sheets
The following video shows how to get started within KeyLAB and how make simple cosmetic changes to your sheets to customise them to fit your aesthetics.
https://vimeo.com/154896357
How to use Reference Cells within KeyLAB2
The following video shows how to get started within KeyLAB and how to use Reference Cells to get data from the database into the sheets.
https://vimeo.com/154898910
How to use Data Cells within KeyLAB2
The following video shows how to get started within KeyLAB and how to use Data Cells to get data from the Input Sheets into the database.
https://vimeo.com/542630596
How to use Grouping KeyLAB2
The following video shows how to get started within KeyLAB and how to use grouping to get more than one test per page into the sheets.
https://vimeo.com/701963121
How to use Ordering and splitting KeyLAB2
The following video shows how to get started within KeyLAB and how to use ordering and splitting on test sheets.
https://vimeo.com/701965703
How to use Equipment Cells within KeyLAB2
The following video shows how to get started within KeyLAB and how to use Data Cells to get data from the KeyLAB Equipment Manager into the sheets.
https://vimeo.com/542633663
How to use Data Row and Columns within KeyLAB2
The following video shows how to get started within KeyLAB and how to use Data Rows and Columns to allow for fast data entry within your sheets to the KeyLAB database.
https://vimeo.com/542632311
How to use Stage Cells within KeyLAB2
The following video shows how to get started within KeyLAB and how to use Stage Cells to allow for fast data entry across tests that have multiple stages within your sheets to the KeyLAB database.
https://vimeo.com/154900363
How to use Staged Row Cells within KeyLAB2
The following video shows how to get started within KeyLAB and how to use Staged Row Cells to allow for fast data entry across tests that have multiple stages and multiple rows of data within your sheets to the KeyLAB database.
https://vimeo.com/154901542
How to Reference other Tests within KeyLAB2 Sheets
The following video shows how to get started within KeyLAB and how to reference other tests that are stored within the KeyLAB database.
https://vimeo.com/154903699
Using Default Values on KeyLAB Sheets
The following video shows how to get started within KeyLAB and how using Default Values can speed up data entry within KeyLAB.
https://vimeo.com/154902451
