KeyLAB General User Videos
The following videos will explain how to get started with KeyLAB, in this case for general users who do not need to know how to administer the system.
Adding a Project to KeyLAB
The following video shows how to get started within KeyLAB and adding a project to the database.
https://vimeo.com/154085822
Adding Locations and Samples to KeyLAB
The following video shows how to get started within KeyLAB and adding locations and samples to a project.
https://vimeo.com/154087149
Adding Schedule to KeyLAB
The following video shows how to get started within KeyLAB and schedule tests for a project.
https://vimeo.com/701978611
How to View and Print Worksheets within KeyLAB
The following video shows how to print worksheets and view them within KeyLAB.
https://vimeo.com/154892185
How to Enter Test Data within KeyLAB
The following video shows how to get started within KeyLAB and how to enter test data.
https://vimeo.com/154150455
Adding Users and Assigning Tests in KeyLAB
The following video shows how to get started within KeyLAB and adding new users to the system and then assigning tests to those users.
https://vimeo.com/154148573
Checking and Approving Tests within KeyLAB
The following video shows how to get started within KeyLAB and how to check tests and then approve tests.
https://vimeo.com/154150098
How to Use the Reporting within KeyLAB
The following video shows how to get started within KeyLAB and how to use the reporting features within the application.
https://vimeo.com/154151344
How to Export AGS Data within KeyLAB
The following video shows how to get started within KeyLAB and how to export AGS data for transfer to others.
https://vimeo.com/154150775
