Did you know that you can use a key-in to open up documents and applications?
_________________________________________________________________________
% keyin - Used to start another Windows application
%calc - would open Calculator
You can use it also to open files from other applications from within MicroStation.
To do that, just add the path to the file after the % character
%c:\temp\test.doc - would open a file name "test.doc" in word.
