| Version(s): | 10.00.00.25 | ||
| Environment: | Windows XP 64 bit | ||
| Area: | Installation | ||
| Subarea: | General |
Bentley Live Player MicroStation Connect Free Trial Minimum Requirements
Note: Windows 7 operating system is supported only if you have its service pack (SP1) installed.
Bentley does not support its software running on Microsoft operating systems versions that Microsoft has "retired". For more information see Microsoft's application retirement policy and the Bentley Application Support Lifecycle.
Internet
Internet connectivity is required to use some of the features of the product and installation of software pre-requisites, if not already installed on the machine.
Communications Protocols
Software Prerequisites
The Prerequisites for Bentley Desktop Applications are automatically downloaded and installed to your workstation while you install MicroStation. The contents of the Prerequisites for Bentley Desktop Applications include:
Microsoft Internet Explorer, minimum v8.0, recommended v9.0 or later, with 128-bit cipher strength is also required. It is not installed as part of the product pre-requisites.
Copyrights in all components are owned by Microsoft Corporation or one of its affiliates, subsidiaries, or licensors.
Supported Databases
The database versions supported by MicroStation are subject to updating after the product release. You can search for MicroStation database support in Bentley Communities for the latest information.
Intel® or AMD® processor 1.0 GHz or greater. MicroStation is not supported on a CPU that does not support SSE2.
Memory
4 GB minimum, 16 GB recommended. More memory almost always improves performance, particularly when working with larger models.
Hard Disk
9 GB free disk space (which includes the 5.6 GB install footprint for a complete installation)
Video
See the graphics card manufacturer for latest information on DirectX drivers. 512 MB of video RAM or higher is recommended. If insufficient video RAM or no graphics card supported by DirectX can be found, MicroStation attempts to use software emulation. For optimal performance, graphics display color depth should be set to 24-bit or higher. When using a color depth setting of 16-bit, some inconsistencies will be noted. For more information on recommended workstation profiles for MicroStation, see MicroStation System Requirements and Hardware Recommendations.
Screen Resolution
1024 x 768 or higher.
| Original Author: | Todd Moser |
