Original Tip Date: Aug 9, 2007
Control the output location of MicroStation Packages
To specify the location of MicroStation Packages, set the variable PZIP_OUT to the folder of your choice.
With thanks to Kirk Elwell for pointing this out on the discussion groups. |
AskInga Tip #735
