Original Tip Date: May 29, 2007
| Run debug from a modified icon | |
| You can create a debug report by modifiying your MicroStation icon. Just add -debug to the command line as shown below. Note: MicroStation will not actually run when in this mode, so remove the -debug from the icon. Or, create a second icon on your desktop just for this purpose. Related Tips: Run Debug From The Command Prompt DOS Window Specify The Folder For Msdebug.Txt | |
AskInga Tip #716 | |
