Original Tip Date: Feb 9, 2007
| Regarding the last line in a configuration file | |
| As many of you know, the last line in a configuration file must end with a carriage return or the line may not be read and digested with MicroStation is fired up. No doubt you'll be pleased to learn that Barry Bentley located and resolved this issue in release 08.08.03.xx. Yeah!! | |
AskInga TIp #697
