Original Tip Date: Feb 26, 2002
| Lock down your variables! | |
| To prevent users from changing variables through Workspace > Configuration, lock down your variables by prepending them with the preprocessor directive %lock. For example, in your site configuration file, you can lock down MS_ENHANCEDPRECISION to a value of 0, by adjusting your configuration to read: MS_ENHANCEDPRECISION = 0 %lock MS_ENHANCEDPRECISION | |
AskInga Tip #135
