Original Tip Date: Jul 9, 2001
| Change the size of AccuDraw's compass | |
| Did you know that you can change the size of AccuDraw's compass? Use the keyin: accudraw settings size number where number is a value between 6 and 399. The lower the value the smaller the compass; the default number is 40. Thanks to Sean "Bear" Forward for submitting this tip! | |
AskInga Tip #112
