Original Tip Date: Jan. 10, 2006
| Save lighting solutions to the design file | |
| In MicoStation V8 XM Edition you can save global particle trace or radiosity solutions to a new model in a 3D DGN file. The exported model will contain mesh geometry with the appropriate lighting values at the vertices but will not display specular or reflective effects. You can view the model from any direction or attach it as a reference. To export the solution just do a right click Render dialog, and choose Save Solution To DGN from the pop-up menu. | |
AskInga Tip #592
