Original Tip Date: Jul 24, 2007
MicroStation's icons | |
Program icons for MicroStation V8 XM edition can be found in: ...\microstation\ustation.exe, and ...\microstation\icons\ustnwin32.dll The graphic below is showing the icons in the dll file. With thanks to Gary Cochrane for pointing this out. | |
AskInga Tip #732
