Original Tip Date: Feb 9, 2007
| Set a background image | |
| To set the background of your design file to an image: Settings > Design File > Views > Background Image Select an image of your choice. Note that the image will be displayed on all views as a background only. You will not be able to select/modify/manipulate it since it's there for display purposes only. Turn the background image on or off via the View Attributes dialog or the following key in: set background on/off/toggle | |
AskInga Tip #699
